TPS? chugs only when warm? H22a
Old Jun 4, 2009 | 05:25 PM
nix94delsol's Avatar
Default TPS? chugs only when warm? H22a
I have an H22a swapped del sol and ive hit a rough patch.
My TPS Sensor is off a little bit, i already knew that, but heres the issue.
The cars acting off (yes, i know my TPS will make it do this) But it seems to do it alot more when the motor gets warm. It idles fine, takes off fine, but when you get onto it it chugs really bad (i was told i was also shooting flames out of the exhaust) it also chugs when im driving normally, just not as violently.
Any ideas? i know the TPS is going to throw it off a bit, but im stumped as to why it does it when its warm.
Old Jun 4, 2009 | 07:34 PM
Default Re: TPS? chugs only when warm? H22a
someones gotta know
and this isnt going to page deuce
Old Jun 8, 2009 | 06:24 AM
Update: i just put premium in (used to run mid grade) and it seems a little better.
any input?
Old Jun 8, 2009 | 06:28 AM
Former User's Avatar
Potential problem in closed loop? Does unplugging the primary O2 sensor eliminate the problem?
Old Jun 8, 2009 | 06:33 AM
wouldnt i throw a code?
i havnt tried it yet, but i will try it.
the only CEL i have is for EGR, which is blocked off.
Old Jun 8, 2009 | 07:25 AM
A bad O2 sensor doesn't always throw a code.
Calibrate the TPS ASAP. Then, you might want to look for an exhaust leak upstream or around the primary O2 sensor and also check the ignition timing with a timing gun.
h22blkhb508
Jan 29, 2013 01:23 PM
Jacob VanMeter
Nov 1, 2010 09:49 AM
H22tuner415
Nov 20, 2008 04:16 PM
EgRaCeRB18C
Jun 21, 2008 02:34 PM
fizzbob7
Jul 8, 2003 05:14 AM
