Will not rev up after"B16 swap"
Old Jun 4, 2009 | 04:14 PM
cam head's Avatar
Default Will not rev up after"B16 swap"
I just dropped in a jdm b16a with original d16y8 wire harness,only things switched as far as wiring is plugs to the alternater,piggyback to obd1, and a piggyback off the dizzy to obd2.
The car starts and runs until you touch the gas, then rpms go down until let off. Ive tried different throttle bodies/tps,and have traced all of my wiring.
car has been down for almost two weeks now so any help would be most appreciated. Thanks!
Old Jun 6, 2009 | 02:15 AM
b16_sol_707's Avatar
Default Re: Will not rev up after"B16 swap"
look for vacuum leaks. What does it idle at?
Old Jun 6, 2009 | 03:04 AM
NACvicSi's Avatar
Sounds like a vacuum leak for sure. Did you bother to replace the hoses?
Old Jun 6, 2009 | 03:53 AM
cam head's Avatar
IT idles between 800 and 1000
Old Jun 6, 2009 | 04:01 AM
cam head's Avatar
NO, I just plugged one vucuum off the back of the manifold.
Old Jun 6, 2009 | 04:06 AM
Natural Aspirations's Avatar
TPS and MAP plugs backwards
Old Jun 6, 2009 | 04:09 AM
cam head's Avatar
When I switched the two it took longer to start and ran worse
Old Jun 6, 2009 | 04:16 AM
What ECU?
Old Jun 6, 2009 | 04:24 AM
try a different map sensor?
Old Jun 6, 2009 | 05:23 AM
cam head's Avatar
What ECU?
using p28 with a skunk2 chip,and have tried the p30,y8,and y7.
Old Jun 6, 2009 | 05:29 AM
cam head's Avatar
I have also tried three different map sensors, not sure if I should vanpire clip the four wires to the ecu for the cfs as a delete.
Old Jun 6, 2009 | 06:59 AM
NACvicSi's Avatar
Those skunk2, spoon, mugen, etc etc eBay chips are trash. Get a ECU for that motor or have a chip burned with the base maps to that motor.
Old Jun 6, 2009 | 04:30 PM
I just made the mistake of having the map and tps backwards today and this is exactly what it did.
Old Jun 6, 2009 | 10:27 PM
hatchnideas's Avatar
tps calibrate properly? any cels?
Old Jun 7, 2009 | 12:26 AM
Adam_b16a's Avatar
Even if the tps isnt calibrated, it will still run the car and let it rev up and everything. It wouldnt cause the problem the op is having. What cel's are you throwing?
dansparkeyASE
Oct 5, 2015 10:29 PM
Mr.Galloway
Oct 3, 2014 09:11 AM
Swoops
Oct 26, 2010 07:28 PM
jgraham0326
30
Jun 8, 2010 08:56 PM
LST2
Dec 27, 2008 04:47 PM
