i need your help really bad ht
Old Jun 4, 2009 | 02:15 PM
worx's Avatar
Default i need your help really bad ht
i get my 94 gsr running and the idle is of the way revs up to 5k then dies i plugged the holes in tb and it kinda fixed so it wat the icav i swapped it ou and the same then another one the same im bout to just block it off. my other problem is the cel it came on for code6 ect iswapped it with th eone in my hatch and its fixed the car still idles bad but the cel goes on..off.......on...off...........on...off......... .............on but no codes someone help please
Old Jun 4, 2009 | 02:22 PM
jdm_bones's Avatar
Default Re: i need your help really bad ht
You could have a bad TB gasket or Intake manifold gasket, spray some carb cleaner around the manifold flange, and the same for the manifold to TB flange...Then report back.
Old Jun 4, 2009 | 04:28 PM
worx's Avatar
just put brand new ones in this morning i blocked of the icav by putting a piece of sheet metal to cover the holes but that doesnt work also when i pull the code i just blinks one its kinda a long blink but its still one blink which means its the o2 sensor which brand new
Old Jun 4, 2009 | 04:41 PM
mrdeadman's Avatar
They let me pick
You should take it to checker and just borrow the code reader, it will give you a little more insight than just the paper clip
Old Jun 4, 2009 | 04:55 PM
worx's Avatar
we cant use the scanner tool here anymore besides its obd 1
my pvc was broken and it was surging from there. i need to know how to block the icav
aarontrini85
Sep 28, 2010 04:52 PM
dcdcdc
Aug 1, 2008 07:08 PM
gsr-2nr
Jan 2, 2008 08:31 PM
silverb18
Sep 11, 2004 02:47 PM
mickeylude
Sep 25, 2002 11:48 AM
