how to adjust blox FPR
Old Jun 4, 2009 | 09:47 AM
bakomack's Avatar
Default how to adjust blox FPR
motor is a b16a2, I have a few bolt on's and ITR cam's.
I use to have an aftermarket fuel rail on but took it off to pass bar.
I have a blox fpr, now when it was on the old fuel rail it was set to 42 psi.
I have the blox fpr on my stock fuel rail and the other day when I checked my plugs they showed it to be running a lean. how do you adjust the screw to richen it up and how do I know how much to turn it? I dont have a gauge anymore.
Old Jun 4, 2009 | 09:51 AM
raiden571's Avatar
Default Re: how to adjust blox FPR
you need a gauge. you can try and go by reading your plugs but this can be difficult when done on the street.
i believe you would turn it clockwise to tighten, therefore tightening the spring inside the diaphragm to increase pressure
Old Jun 4, 2009 | 09:54 AM
bakomack's Avatar
can you put a gauge on a stock fuel rail? if I tighten the spring is that richening it up?
Old Jun 4, 2009 | 10:45 AM
bakomack's Avatar
anyone?
Old Jun 4, 2009 | 10:50 AM
raiden571's Avatar
tightening the spring would richen it up. you can put a gauge on it. it can be done a few different ways. you can attach it to where the fuel line goes into the fuel filter, use fancy AN lines, tap the fuel rail for the proper threads or on the end of some fuel rails there is a plug. you could remove that plug and use its hole for the gauge
Old Jun 4, 2009 | 10:59 AM
bakomack's Avatar
what would be a good starting point for adjusting? half turns, quarter turns?
Old Jun 4, 2009 | 11:06 AM
seadonkeyraypiss's Avatar
You need a gauge to find out how much your adjustments are affecting the fuel pressure. No way around it.
Old Jun 4, 2009 | 11:09 AM
bakomack's Avatar
aww see you had to go and pop my bubble
Old Jun 5, 2009 | 06:12 AM
raiden571's Avatar
i would buy the gauge as well. take out the guessing. you arent going to gain power by changing it from stock
Old Jun 5, 2009 | 07:57 AM
bakomack's Avatar
I have a gauge, not looking to increase power just tryin to richen it up because my plugs show im running lean
Old Jun 5, 2009 | 12:56 PM
raiden571's Avatar
are you properly checking them, i.e, do a full throttle pull to redline and kill the motor IMMEDIATELY after, pull the plugs and check? cause if not the only thing pulling them is going to tell you is how it runs at idle, which should be lean anyway
Old Jun 5, 2009 | 01:18 PM
bakomack's Avatar
hmm I didnt know that
Jonathan_ED3
Sep 9, 2012 08:20 PM
jorge59la
Mar 23, 2007 09:11 PM
91integraLSVTEC
Oct 6, 2006 04:50 PM
AgentJam
Oct 26, 2004 04:33 PM
