high compression zc
Old Jun 4, 2009 | 07:54 AM
efjones9's Avatar
Default high compression zc
i am trying to bulid a high compression zc all motor. has anyone done this? im sure some one has. does anyone have a parts list of whats needed? go ahead and chime in on this. im just curious. because i have a zc block laying around. and just got a good deal on a b16. just wondering what would be cheaper to bulid? thanx
Old Jun 4, 2009 | 09:33 AM
Red_ED8's Avatar
Default Re: high compression zc
Build the zc. This way you don't have to buy mounts and etc. Slap some p29's in it, a good cam and get the head ported. And after all that its still cheaper (and more powerfull) then swapping a b16.
Old Jun 4, 2009 | 10:52 AM
dephtone's Avatar
Is this the DOHC ZC or the SOHC ZC? If it's the DOHC it already has pm7/p29 pistons in it, they are both the same dome, but if it's the SOHC zc then yes throw the p29's in it and rock that for awhile. SOHC ZC + p29's = pretty fun all motor D series.
Old Jun 4, 2009 | 02:56 PM
efjones9's Avatar
yea my bad its a sohc. i was reading and saw that dished pistons are better for all motor than domed? did i read it wrong or what? also what are the best rods?crank? to go with the combo?
Old Jun 4, 2009 | 03:19 PM
Red_ED8's Avatar
It all depends on your plans for the car. As far as I know the A6 (sohc zc) has the best bottom end out of all the D's. So just keep your stock bottom end + some arp rod bolts and some new bearings/journels and you should be golden.
Old Jun 4, 2009 | 03:23 PM
efjones9's Avatar
i want to go all motor the cheap way tho lol. i know it could be expensive but want something that i could dd without the CHP on my as* when i hit the highway. any good place to get good bottom end rebulid kit?
Old Jun 4, 2009 | 04:19 PM
SkRoMeEnIzANoNo's Avatar
im trying to do the same thing ur doing check this site they got rebuild kits for u http://www.fjdistributors.com/
also.. check out www.d-series.org learned alot of stuff from there goodluck bro
Old Jun 5, 2009 | 09:29 AM
efjones9's Avatar
thanx good info
Old Jun 10, 2009 | 08:32 AM
oilspot's Avatar
http://hondamarketplace.com/showthre...5#post38796451
You should really take care of this!
Old Jun 25, 2009 | 12:00 PM
efjones9's Avatar
stock or is aftermarket better?
Old Jun 25, 2009 | 03:37 PM
hatch_kidb18b1's Avatar
Hey just finished my build using stock OEM Honda parts. Used zc pistons from a sohc with y8 head and gasket with a 1.5 block also milled the head made 160 whp with no vtec and stock can cost me about 500. And the arp kit cost me 200 I suggest doing this build so much better they a b16 mad 12.98:1 comp
Old Jun 25, 2009 | 03:47 PM
efjones9's Avatar
so u used a d15bx block?? and u got 12.98:1 compression?
Old Jun 25, 2009 | 03:57 PM
DCRB's Avatar
heh i'm doing something similar to you guys... i've got an a6 bottom end with pistons and rods, going to be getting a y8 head gasket and i've got a z6 head i'm throwing on it. should be fun
hasty91ef
19
May 30, 2011 02:57 PM
bacnoonoi
16
Oct 3, 2008 08:36 AM
4door93civic
Feb 1, 2008 08:46 PM
1badrex
Dec 26, 2003 04:48 AM
91ReXSI
Dec 2, 2001 08:06 AM
