ok alittle help with electrical?!?!?!?
Old Jun 4, 2009 | 07:37 AM
royaltrex7's Avatar
Default ok alittle help with electrical?!?!?!?
Ok for starters I have a 97 del sol with a d16y8. I drove for about 25 miles to my parents' house. Park the car and work on their neighbor's car. About 3 hours later I go to start and no spark. I checked wires and plugs no spark. changed out dizzy wires and plugs. Still no spark...................... WELL LO AND BEHOLD I FORGOT SOMETHING THAT WASN'T HAPPENING TO BEGIN WITH..... My interior light and trunk light won't come on either.... Any ideas????? This is my daily driver fast responses greatly appriciated.
Old Jun 4, 2009 | 07:57 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: ok alittle help with electrical?!?!?!?
check your ecu fuse...is your battery dead. whats up with the lights?
Old Jun 4, 2009 | 08:03 AM
98civdx's Avatar
Master Detailer
check some fuses....
do your head lights turn on??
Old Jun 4, 2009 | 08:44 AM
royaltrex7's Avatar
All my headlights work. My radio, all fuses are good. Changed out ground wires ect..... Batteries are strong. Oh yeah I have 2 batteries optima yellow top and a duralast. They check out and have been wired for 2 months correctly
Old Jun 4, 2009 | 12:34 PM
royaltrex7's Avatar
ok update i changed out my ground to my tranny as well as my block and i still have the issue
i appoligize for typing but im greasy
Old Jun 4, 2009 | 01:20 PM
98civdx's Avatar
Master Detailer
im stumped.
is the duzzy getting power at the plug?
Old Jun 4, 2009 | 03:35 PM
royaltrex7's Avatar
which wire do i check at the plug what should voltage be? and if its not what do i do?
Old Jun 4, 2009 | 03:45 PM
civicx's Avatar
Try to jump the car, sometimes even everything works but won't start. Also check your starter, maybe its dead. Last time happened to me while driving back from work. I stop by my friend's house and 1 hour later, I start my car to go home but won't start, its turn out to be my starter is dead. After changing the starter, everything works fine.
Old Jun 4, 2009 | 05:06 PM
98civdx's Avatar
Master Detailer
im looking but cant find anything. the search button sucks.
try just unplugging it while some trys to crank it with a multi meter check the wires to see if theres 12 volts in any of them.
Old Jun 4, 2009 | 06:02 PM
royaltrex7's Avatar
black with yellow stripe and i fixed the problem i now have fire and fuel but not starting? spark plugs have fuel on them i think motor is flooded now. how can i fix that?
Old Jun 4, 2009 | 06:27 PM
98civdx's Avatar
Master Detailer
try push starting it... if it runs at least it wont be flooded anymore.
then shut if off and try starting it.
SF_Dee
Jun 23, 2010 07:07 PM
JAYDmManny1331
Nov 22, 2009 09:33 PM
crxricer66
Sep 10, 2007 01:41 PM
smoovekriminal
Aug 17, 2007 09:55 PM
billybob
20
Aug 29, 2004 07:02 AM
