ok alittle help with electrical?!?!?!?
Old 06-04-2009, 07:37 AM
royaltrex7's Avatar
Default ok alittle help with electrical?!?!?!?
Ok for starters I have a 97 del sol with a d16y8. I drove for about 25 miles to my parents' house. Park the car and work on their neighbor's car. About 3 hours later I go to start and no spark. I checked wires and plugs no spark. changed out dizzy wires and plugs. Still no spark...................... WELL LO AND BEHOLD I FORGOT SOMETHING THAT WASN'T HAPPENING TO BEGIN WITH..... My interior light and trunk light won't come on either.... Any ideas????? This is my daily driver fast responses greatly appriciated.
Old 06-04-2009, 07:57 AM
I'm not Rick!
rick_rabies's Avatar
Default Re: ok alittle help with electrical?!?!?!?
check your ecu fuse...is your battery dead. whats up with the lights?
Old 06-04-2009, 08:03 AM
Master Detailer
98civdx's Avatar
check some fuses....
do your head lights turn on??
Old 06-04-2009, 08:44 AM
royaltrex7's Avatar
All my headlights work. My radio, all fuses are good. Changed out ground wires ect..... Batteries are strong. Oh yeah I have 2 batteries optima yellow top and a duralast. They check out and have been wired for 2 months correctly
Old 06-04-2009, 12:34 PM
royaltrex7's Avatar
ok update i changed out my ground to my tranny as well as my block and i still have the issue
i appoligize for typing but im greasy
Old 06-04-2009, 01:20 PM
Master Detailer
98civdx's Avatar
im stumped.
is the duzzy getting power at the plug?
Old 06-04-2009, 03:35 PM
royaltrex7's Avatar
which wire do i check at the plug what should voltage be? and if its not what do i do?
Old 06-04-2009, 03:45 PM
civicx's Avatar
Try to jump the car, sometimes even everything works but won't start. Also check your starter, maybe its dead. Last time happened to me while driving back from work. I stop by my friend's house and 1 hour later, I start my car to go home but won't start, its turn out to be my starter is dead. After changing the starter, everything works fine.
Old 06-04-2009, 05:06 PM
Master Detailer
98civdx's Avatar
im looking but cant find anything. the search button sucks.
try just unplugging it while some trys to crank it with a multi meter check the wires to see if theres 12 volts in any of them.
Old 06-04-2009, 06:02 PM
royaltrex7's Avatar
black with yellow stripe and i fixed the problem i now have fire and fuel but not starting? spark plugs have fuel on them i think motor is flooded now. how can i fix that?
Old 06-04-2009, 06:27 PM
Master Detailer
98civdx's Avatar
try push starting it... if it runs at least it wont be flooded anymore.
then shut if off and try starting it.
SF_Dee
06-23-2010 07:07 PM
JAYDmManny1331
11-22-2009 09:33 PM
crxricer66
09-10-2007 01:41 PM
smoovekriminal
08-17-2007 09:55 PM
billybob
20
08-29-2004 07:02 AM
Quick Reply: ok alittle help with electrical?!?!?!?
