Spraying B16A before crossover?
Old Jun 3, 2009 | 08:48 PM
LOV2XLR8 94Z28's Avatar
Default Spraying B16A before crossover?
I swapped motors in my daily driver, and set up a Nitrous Express Wet kit. I've been spraying a 50 shot with a window switch/wot sensor at 5,200 RPM. The phearable.net programming I am running set Vtec at 5,100 which I think is stock any ways. My question is, I know during the Vtec crossover the motor has a tendency to run a little lean. I've heard it's not ideal to spray during cross over since it's running kinda lean to begin with. The switch I am running is a nitrous outlet rpm/tps and dual stage window switch. I was thinking maybe diode isolating it, having it spray from 3,000-5,000 then again at 5,200 - 8,400, 200 rpm before my limiter. I know the Vtec dip would be hellaciously bad. Or if I could just run it from 3,000 - 8,400. I've got an AEM uego Wideband on the way, I checked all 4 plugs after spraying each time. They looked fine. To run a 75 shot do I need to start retarding the ignition? Or is stock timing okay?
I did search, this forum, and google, haven't been able to find the exact info im looking for though.
Thanks.
Old Jun 3, 2009 | 09:28 PM
SIred91's Avatar
Rainman
Default Re: Spraying B16A before crossover?
Forced induction forum on here has some nitrous gurus in there......
Old Jun 4, 2009 | 02:06 AM
efkilla's Avatar
im running a nx wet kit 75 shot no window switch just on switch in the cabin then spray and pray im on a stock map it runs like a f!@# champ jus dont missed shift and turn up the gas a lil
wushubrian
20
May 2, 2006 07:50 AM
DA jeshy
Feb 19, 2006 12:17 AM
sik civic
Jun 13, 2005 12:57 PM
gookspeed
Mar 7, 2005 11:23 AM
nitrouspete
Nov 2, 2003 12:40 PM
