Suspension & Brakes Theory, alignment, spring rates....
bleeding problem
Old Jun 3, 2009 | 06:48 PM
tegdude227's Avatar
Default bleeding problem
i just deleted abs on my 97 integra and replace the brake booster, master cyclinder, and prob valve with ones off a 94 civic. i bench bleed the master cyclinder and then bleed the brakes a bunch of times. for the life of me i cant get the pedal to be stiff. i have about an inch of play before the brakes start to engage. could this be from the prop valve or any of the other parts or is it just me bleeding them ?
Old Jun 4, 2009 | 12:41 AM
xd69's Avatar
Default Re: bleeding problem
What calipers do you have and what size MC did you install???
Old Jun 4, 2009 | 11:40 AM
tegdude227's Avatar
i have gsr calipers. and a 13/16 mc was installed sould i put a 15/16?
Old Jun 4, 2009 | 01:43 PM
xd69's Avatar
Theres your problem! That mc was designed for a civic with 9.5 inch brakes in the front!
You should definitely get a 15/16 or a 1" for a more stock feeling brake pedal
Old Jun 4, 2009 | 07:56 PM
tegdude227's Avatar
alright well i have a booster off a civic also so wat are my options. i heard that i can get a mc off a 94 civic cx 4 door they are 15/16 i beleive correct me if im wrong
Old Jun 6, 2009 | 12:49 PM
PyroProblem's Avatar
Id go with the full 1" master cylinder. Pedal feel is amazing!
I think i found mine on some old 4D integras with ABS at the junkyard.
BoldFart16
Jun 6, 2010 05:45 PM
verycleanhatch
Suspension & Brakes
Sep 4, 2009 01:34 PM
xiongtoua1990
12
Jul 19, 2008 12:37 PM
taney
Jan 22, 2006 08:49 AM
0ptimus prime
Sep 12, 2005 05:46 AM
