LC-1 Help with crome and freelog
hey, i jsut got my lc-1 wideband. now i know that the stock ecu cannot read over 3.75 volts from the wideband, so how do i set it up so that the wideband wont send over 3.75volts? do i program that in the logworks program that came with the wideband or through crome and freelog? thanks in advance.
It is all right in the instructions.
Page 12 and 13 here.
http://www.innovatemotorsports.com/s...C-1_Manual.pdf
I would have to say that this is the answer to 90% of H-T's "technical" install questions. You should always read and understand the installation & operating instructions prior to installing any component.
If something you read doesn't make sense, read it again. If it still doesn't make sense, you should probably have someone else install the part for you.
do you really need to read over 3.75(over a 17afr) volts anyways? Just hook it up directly to the ecu, add correct voltage settings in freelog, and start logging.
heel_touge
Engine Management and Tuning
May 14, 2009 09:48 AM
SFlCrx
Sep 18, 2007 12:14 PM
