a/f install Q
a/f install Q
I put my a/f gauge in the otehr day, and i hooked it up right off the ecu, make any diff in accuracy if closer to the sensor or ecu, possible signal drop?
unless you're running a wideband o2 sensor, there isn't anything that you can do to make them accurate. Using the stock narrowband o2 sensor, they're just pretty light shows.
