1991 Ls seats into 1991 crx
Old Jun 3, 2009 | 05:02 PM
JDMkid413's Avatar
Default 1991 Ls seats into 1991 crx
i just traded for a 1991 crx dx and the seats are all torn up so i thought i would throw in my Ls seats i have laying around and i cant seem to get them to fit... i tried switching the seat rails but that wont work... so i need help give me some info or redirct me to a thread that could help me out...
Old Jun 3, 2009 | 05:07 PM
crx_si-r's Avatar
Default Re: 1991 Ls seats into 1991 crx
you have to swap out the entire seat pan with the rails. do that and your good to go.
Old Jun 4, 2009 | 04:46 AM
JDMkid413's Avatar
oh so i have to use the crx "seat pans" meaning the part you sit on? or can i use the Ls cushions?
Old Jun 4, 2009 | 05:14 AM
NFRap1's Avatar
swap out the metal seat pan. use the integra cushion
Old Jun 4, 2009 | 05:57 AM
JDMkid413's Avatar
oh ok i think i got an idea now... is the cushion glued on?
Old Jun 4, 2009 | 08:00 AM
LittlesilverEF's Avatar
Just get a long screw driver and stick it in between where the coushin meets the metal seat pan and just gently pry it out.
Be gentle though because the foam can tear.
I swapped my seats twice, first from an EG and then for 90 si seats in my 89 dx.
There's a write up in the FAQ thread.
Old Jun 4, 2009 | 08:25 AM
JDMkid413's Avatar
can you point me to the faq thread with a link?
Old Jun 4, 2009 | 08:30 AM
Here ya go:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/my-how-swap-seats-88-89-ef-2189540/
This guy even used Integra seats and the pictures are still there.
It's actually fairly easy, I can answer any questions you might have.
Old Jun 4, 2009 | 02:17 PM
JDMkid413's Avatar
well in that faq thread it shows switching up the top and bottom parts of the seats but i also heard i could just switch the seat pans and it will line right up so what is correct?
Old Jun 4, 2009 | 02:51 PM
Radim's Avatar
Just go for it, it's easy and self explanitory when you start doing it.
I didn't even read the FAQ just went ***** out.
When i seat pan swapped 91 SI seats to my 89 Hatch i had to switch the top halves of the seats too. Wasn't hard.
Old Jun 4, 2009 | 03:00 PM
JDMkid413's Avatar
yea well i would like to do as little work as possible... im jus gonna try the seat pan swap first...
Old Jun 4, 2009 | 09:11 PM
Yea I'm not sure if you can bolt up the top half of the DA seats to the EF seats.
That would be the easiest and most ideal situation though because it kind of sucks getting the fabric off of the top of the seats.
Definitely worth a try!
Old Jun 4, 2009 | 09:20 PM
Eighty-Nyne's Avatar
When I did mine, I had to swap EVERYTHING. Seat pan and back rest skeleton thing...you're lucky you don't have an 89 haha.
Old Jul 18, 2012 | 08:24 PM
NJ-JDM's Avatar
Has anyone tried this with Prelude seats? I am guessing they are all fairly similar.
Thanks
Old Aug 3, 2012 | 06:53 PM
JDMkid413's Avatar
One of my buddys had prelude seats in his ef.. I think they bolt right in but I'm not sure..
Danthemagicbum
Apr 29, 2011 05:57 AM
crazyboy
Sep 9, 2009 12:52 AM
1988crxdx
Jun 3, 2009 12:51 PM
hybrid1990crx
10
Mar 4, 2004 10:14 PM
