GSR not getting spark
Old Jun 3, 2009 | 11:37 AM
aguynamedpat's Avatar
Default GSR not getting spark
Well my buddy picked up a 95 GSR with a B18C in it the other day. We compression tested the car, and after we were done we could not get any spark. We are definitely getting fuel, but we are not getting any spark.
The coils in the distributor tested good and the ignition control module tested good as well. We still have to make sure the distributor is getting power from the ECU.
Its not timing related, the rotor turns when you turn the car over. It will just keep turning over but wont crank. The cap and rotor look to be in good shape as well.
Anyone have any ideas?
Old Jun 3, 2009 | 01:18 PM
LOVEthatDC2's Avatar
Default Re: GSR not getting spark
happened to me once with a b16, turned out to be the igniter. but you said it tested good ... bad wires?
Old Jun 3, 2009 | 01:29 PM
My bad, should have mentioned that plugs are good and wires are brand new as of yesterday.
Checked all fuses and they are good.
Old Jun 3, 2009 | 01:32 PM
so it worked before the compression test was done? then after it didn't?
Old Jun 3, 2009 | 01:34 PM
Yep. Cranked right up and drove great before the compression test. I had personally driven it 4 times, and he said it NEVER gave him trouble before the test.
Old Jun 3, 2009 | 05:07 PM
OrangeTeggy's Avatar
Check the coil, thats what was wrong with my car
Old Jun 3, 2009 | 05:42 PM
Fastasscar's Avatar
just change the whole distributor. Try that, if not return it. Don't just change parts.
Old Jun 3, 2009 | 06:39 PM
mrdeadman's Avatar
They let me pick
Is the rotor underneath the dis cap spinning when you crank? If not it is the timing belt.
Old Jun 3, 2009 | 07:40 PM
blkb18's Avatar
If your compression test was good I wouldnt worry about the timing belt. I had my dizzy go on me with no prior warning, just cut out like a switch on me one day while driving. The sensor inside the dizzy for the cam position went bad. It could have happened when you were cranking over the motor on the compression test. What did you do to dissable fuel for the compression test?
Old Jun 3, 2009 | 08:35 PM
Mrdeadman- Yes the rotor turns. I covered that in the original post ;-)
blkb18: We didnt do anything to disable fuel for the test. We didnt even unplug the dizzy. I told him we should unplug the dizzy just to be safe and he said we didnt need to, we could just pull all the wires and it wouldnt crank (obviously). But I am wondering if we did any damage to the dizzy by not unplugging it.
And compression was right around 180 all the way across, give or take 3psi or so.
Old Jun 4, 2009 | 03:32 AM
blkb18's Avatar
I dont think you damaged anything by doing that. Your numbers may be a bit higher than they should be because of the fuel you allowed to spray in the cylinder. You sort of did a wet test.
xolk88
Mar 7, 2010 02:45 PM
jdm_sai
18
Feb 16, 2010 05:19 AM
aguynamedpat
Jun 4, 2009 07:30 PM
Honda Hick
Feb 28, 2005 09:20 AM
KaRiZMa
Nov 1, 2004 04:19 AM
