Brake Booster Problem? NEED HELP!!
Okay, I just recently swapped the whole GSR disc conversion (front&rears), new pads, new brake hose, new master (15/16), and a used 40/40 proportioning valve and GSR booster (290V). I'm having a wired problem, when I'm driving the car it brakes fine, but after awhile the brakes lockup? after it cools down its fine. My question is, is this a possible cause of a bad booster? Like I think the booster rod is getting stuck or something. Also it has a vacuum leak (where the master bolt's to the booster) is this a problem?. Has anyone have this problem? Also can't I just swap over the DX stock booster and used the 15/16 master? Please help me,
Thanks.
Thanks.
The vacuum hose that goes from the intake to the brake booster is backwards...yes it matters what way the valve thingy in the middle is facing.. go to www.kenskustomchassis.com and order a boosterless mastercylinder..i did. its real nice...and clean
Markb16a
May 27, 2010 08:36 PM
