EK egine won't start after alarm removal
Old Jun 2, 2009 | 08:46 PM
VotinhAccord95's Avatar
New User
Default EK egine won't start after alarm removal
Please help!!!
I bought the civic EK 2000 dx, and I try to convert to power window. I bought the floor harness from EK SI 2000 and have replaced it completely. After that I found an old alarm system in the car, but which is not working; therefore, I remove all the brain,sensor,relay, and harness. I also took the fuse box out, after that I plugged everything back in. Now everything work fine; signal, headlight,and other etc, but the engine. I try to start, it sound like normal like it would start, but no. it crank, but the engine won't run. I gave up and don't know what wrong with it. Thank you!
Old Jun 3, 2009 | 03:23 AM
b16_sol_707's Avatar
Default Re: EK egine won't start after alarm removal
when you turn the key on (right before start), does the fuel pump prime? if not it's either a fuse or the main relay.
Old Jun 3, 2009 | 05:29 PM
New User
Thank for the hint.. I will check that out, but before that the engine were running fine.
Old Jun 3, 2009 | 05:47 PM
Zumo's Avatar
Make sure your coil is getting power.
Old Jun 3, 2009 | 05:54 PM
Former User's Avatar
As mentioned, listen for whether the fuel pump primes and also whether there is spark at the plugs.
Dan Fizzle
Jun 18, 2006 05:27 PM
Tony Starks
Sep 20, 2003 07:34 AM
redline201
Audio / Security / Video
Jul 31, 2003 08:35 PM
