wat wire do i use on distib for tack?????????????
Old Jun 2, 2009 | 08:39 PM
boostedd15b714b's Avatar
New User
Default wat wire do i use on distib for tack?????????????
i need t0 know wat wire i hook in t0 on a 95 honda civic d15b7 2 run my tack?????
Old Jun 2, 2009 | 08:48 PM
D16SiHatch's Avatar
Default Re: wat wire do i use on distib for tack?????????????
if you're trying to hook up a 5" sunpro monster tach, please don't. just get yourself a gauge cluster that already has a tach in it to begin with. you'll thank me later
Old Jun 2, 2009 | 08:49 PM
xXBoostfre@KXx's Avatar
(-) side of the coil is the correct wire
Old Jun 2, 2009 | 08:51 PM
Tractor_Boy's Avatar
so Hondas dont say Tach/Test? and yes, it is always the negative side, unless you have a positive ground vehicle
Old Jun 2, 2009 | 08:52 PM
New User
its not a sunpro tach i dont buy junk its a sport comp carbon 5 inch its a lil goddy i think 2 ,but i want 2 be carful with this motor
gsrpedro's Avatar
i think its the blue one
Old Jun 2, 2009 | 08:57 PM
New User
its the soild blue one????
Old Jun 2, 2009 | 08:58 PM
D16SiHatch's Avatar
yes its the solid blue wire at the distributor. i'm pretty sure this wire is available behind the cluster though, but don't hold me to that. that's how it is on an ed/ef chassis anyway. it sounds so ghetto running a wire out to the engine bay to run any tach in general. i dunno that's just me.
Old Jun 2, 2009 | 09:01 PM
New User
your right it looks getto 2 but i cant find a good dash set anywear and in not paying 200 hundred for a used one from so ones beater car ill get a type r cluster soon this is just 2 hold my over 2 run the car
Old Jun 2, 2009 | 09:07 PM
gsrpedro's Avatar
take out the tach and look at the plugs is the blue wire for the rpms
Old Jun 3, 2009 | 05:25 AM
its crazy how kids today are to lazy to open a book and look up the the wiring on their car....... no offense OP
Old Jun 3, 2009 | 05:31 AM
trustdestruction's Avatar
Why would you tap in at the distributor?
The wire is right there behind the cluster...
'tis blue
wtf... you can buy a used EX cluster for the same price or even less than you paid for the ugly *** tach. Direct swap, no wiring required, nothing. Easier than cake, and doesn't look like ****.
Old Jun 3, 2009 | 05:48 AM
yup, its a sad thing
Old Jun 3, 2009 | 06:13 AM
R666_EK's Avatar
Who gives a **** about even having a tach right now? I ran my DX with no tach for over a year. Just use your ears. Listen to the engine. Do it right and just buy an EX cluster. I ABSOLUTELY HATE when I see cars with those big tachs sitting there. Makes me embarrassed to drive my Honda sometimes.
However... IF you really want that thing in there just use the wire behind the cluster as previously mentioned. The car is already prewired for it.
Old Jun 3, 2009 | 06:25 AM
X2^^^^
who puts a tach on a 1.5 anywho, I think the tach has more performance than the engine.....
Old Jun 3, 2009 | 07:20 AM
most of my lawn tractors probably have more power than that thing and I dont need a tach, as R666 EK said, learn to use your ears, hell I been drivin manual transmissions since before I could legally drive and never needed a tach.........................
Old Jun 3, 2009 | 07:53 AM
civic_driver's Avatar
You need a tach when adjusting idle speed or when you're inspecting/setting timing. Also, if you have a manual transmission, it helps to know at what rpm you're shifting.
Old Jun 3, 2009 | 07:57 AM
its basically just a diagnostic tool, yeah it may look cool but ya dont really need it...... which leads to something I've never quite understood, why do more automatics come with tachs and most manuals dont???? makes ya wonder
Old Jun 3, 2009 | 08:24 AM
My automatic doesn't come with tach but then again I got the value package It depends what model Honda you have.
Old Jun 3, 2009 | 08:37 AM
I was just sayin cars in general, and yeah usually the economy models dont have it, just seems odd to have a tach in an auto instead of a manual, u'd think it would be base to have a tach in a manual trans car.....
civiclxb16a
Apr 30, 2005 09:37 PM
92'gsrhatch
Jun 2, 2003 06:37 PM
NeedACivic
May 7, 2003 01:57 PM
civicracer1993
Sep 17, 2002 10:53 PM
cw_civic
Jun 17, 2002 11:32 PM
