DRAG3 LSs using Z10 traction bars?
just wondering if any of you turbo LS folks are usin Z10 traction bars. if so... did the pipes clear? if not, how much modification did you have to do?
Smarter than you
just cut about in inch off the vertical intercooler pipe that connected with turbo. thats it, after that it fit fine.
I was surprised how easy it was to modify. I was there when DIRep972 did his and it took only like 30min to finish everything. Cheap, fast, reliable. Pick 2..
art
art
Smarter than you
well, i kinda ended up with the radius arms on accident, its a long story but i traded a fluidyne radiator for them. I never had a problem with wheel hop before and I sure as hell dont know. but right when i put the radius arms on ive noticed a huge difference in handling, the suspension is much more predictable now and i can toss the front end around so easily. the back end feels like a truck compared to the front now. top speed stability is alot better too, not that i do those things, but i did notice a difference when cruising 100mph. and even braking feels like its been improved, could be my imagination though. now i need to get to the track and test them for luanching finally.
