Traction Bars????
Old 06-27-2005, 07:21 AM
supaman111's Avatar
Default Traction Bars????
What are traction bars and where do they fit, any1 got any pics. I am in the UK and never heard of them before.
Old 06-27-2005, 07:34 AM
chameleon's Avatar
Default Re: Traction Bars???? (supaman111)
try doing a search, they are pretty common, they help eliminate wheel hop which is the main cause of broken axles. they bolt to where the front tow hooks are on the bottom of the radiator support side frames
Old 06-27-2005, 07:43 AM
veggiemaster's Avatar
Default Re: Traction Bars???? (chameleon)
they basically keep a little bit of tension or 'load' on the front lca's to eliminate wheel hop, exactily what chameleon said.
The main problem that i have seen with them is that they add some positive caster to your alignment and cause your tires to wear a bit quicker, but they do perform quite well.
SilverPanda
Suspension & Brakes
09-04-2007 01:37 PM
ghostsi69
Suspension & Brakes
13
12-03-2005 12:58 PM
itsJDMyo
18
11-04-2005 08:10 AM
turbospool
06-10-2003 04:30 PM
KoRE
10-17-2002 08:24 AM
Quick Reply: Traction Bars????
