H22 swap into 4th gen problems
Ok guys i am doing a jdm h22 swap into my girls accord. 92 lx auto. I used the mount's from explicitspeed to convert to 5 speed and install the h22 swap. i ran the wires for the vtec, iabs, knock sensor. extended the oil pressure wire etc etc. Now the problem im having is when i run the jdm prelude computer im getting a map sensor code. I searched and found some people saying to use a dx civic map with the jdm ecu. Ok so i followed the wiring in the etm. ( acura tech here) hooked it up starts it up code 5. Map sensor. what am i doing wrong? if i hook up the accord computer and map sensor no codes obviously. can someone please tell me all the correct wiring i need to do to get this car running and out of my hair.
When I did my h22a swap into a 5th gen, I thought I was getting a code 5, but the last blink was a short...so it was really getting a code 41, o2 sensor. Check to make sure that the 5 blink is really a long blink. Hope this helps.
djnikko
Jan 13, 2010 07:23 PM
Stegemann
Aug 23, 2005 09:40 PM
