ECU problem
Old Jun 2, 2009 | 10:55 AM
88 EF Hatch's Avatar
Default ECU problem
Alright so I have an EF with LS swap. My motor ran fine before, but my fan didn't trun on. So while I trouble shooted that, I did accidently touch pos and neg like 3 times. Anyways I fixed fan and when I when to turn car on I didn't get any spark. So I checked ecu and I'm not getting any respond. Its a obd0 PR$ and the led light is not even blinking once. I'm not getting any fuel. So my ecu is not grounding main relay. I swapped dizzy's and ecu's that are know to be in working condition and same problem. What went wrong?
Old Jun 2, 2009 | 11:04 AM
dephtone's Avatar
Default Re: ECU problem
There is a fuse under the hood for the ecu. This supplies the power to the ECU. Im 99% that fuse is blown and not giving you power to you ecu which it can't supply power to the main relay which cant turn on the fuel pump.
Old Jun 2, 2009 | 11:17 AM
like i said the fuse is not blown
Old Jun 2, 2009 | 12:29 PM
dephtone's Avatar
Check the fuse in the underdash #14 Alternator Solenoid valve...
I don't see anywhere that you said you check the ECU fuse under the hood you just said you get no response from the ECU, hence why I suggested to check the fuse.
Old Jun 2, 2009 | 01:31 PM
sh!ft's Avatar
Who the fack changed my title?!
and some times the pos wire in the same fuse box coming off of the pos battery cable. i had a small problem with that before
TANGO28
Engine Management and Tuning
Aug 11, 2008 02:28 PM
brasiliangee90
Apr 25, 2008 11:40 AM
flipsyde
11
May 1, 2007 08:35 PM
Carbcivic
15
Oct 16, 2005 06:28 AM
chuckd05
Nov 6, 2001 08:13 AM
