7psi spring making 11psi steady, how come?
Old Jun 2, 2009 | 10:19 AM
R.A.T.'s Avatar
Default 7psi spring making 11psi steady, how come?
Just curious,
I have a top mount with 2 Tial wastgates 44mm, they each have a 7psi spring in them yet they go up to 11psi and hold steady, no creep no nothing. I'm not complaining but can anyone explain to me why it does this? (obviously this happens without a boost controller hooked up to it)
Old Jun 2, 2009 | 11:14 AM
Neonxiii's Avatar
Default Re: 7psi spring making 11psi steady, how come?
Originally Posted by R.A.T.
Just curious,
its probably just as simple as your setup
Old Jun 2, 2009 | 12:10 PM
TiAL's Avatar
low backpressure, non optimal priority on the manifold, taking the source off the intake manifold but having a boost gauge source by the turbo
to name a few
Old Jun 2, 2009 | 12:18 PM
96 GSR-T's Avatar
I would think that even with less than optimal WG placement Dual 44's would still hold boost at w/e the WG springs are rated for, I dont think I have ever seen a Topmount with teardrop cutouts on the runners they all look like 90 bends from what I have seen.
Old Jun 2, 2009 | 12:23 PM
R.A.T.'s Avatar
Here's a pic of the manifold,
3" downpipe with no cat 3" thermal r&d
reading boost off the intake manifold
Old Jun 2, 2009 | 12:26 PM
D-Rob's Avatar
That's the two I'm gonna' go with.
- Derek
TiAL's Avatar
if you don't have the priority, it doesn't matter what wastegate you have
Old Jun 2, 2009 | 12:39 PM
92redhatch's Avatar
WHAT DO YOU MEAN BY PRIORITY? IM HAVING A SIMILAR PROBLEM. BUT IT HAPPENED AFTER I WENT FROM A 11PSI SPRING TO A 7
Old Jun 2, 2009 | 12:40 PM
AJxr's Avatar
7+7=11
duh
Old Jun 2, 2009 | 12:41 PM
R.A.T.'s Avatar
I don't think it's a problem for me, I'm just curious why. Or... is it a problem?
Old Jun 2, 2009 | 12:55 PM
92redhatch's Avatar
its a problem because if you put a 7psi spring it should be boosting 7 psi.
Old Jun 2, 2009 | 01:00 PM
R.A.T.'s Avatar
It doesn't spike nor creep to 11psi, it holds steady, it seems as if the springs inside were made for 11psi. Since it holds steady, we simply tuned it around that power level. This is why we don't see it as a problem. Either way, we planned to go more than 11psi, (actually running at 18psi)
Old Jun 2, 2009 | 01:06 PM
TiAL's Avatar
direct flow of exhaust gas to the wastegate, i.e. it doesn't have to make a 90* turn
crvtectim
Feb 14, 2012 12:54 PM
91integraLSVTEC
Oct 21, 2009 11:09 AM
blackeg
Mar 18, 2008 09:31 PM
RTW DC2R
Mar 24, 2006 06:33 PM
shingles
Jan 24, 2003 01:58 AM
