please help! squeal from front pass. side of car.
so i've got this real annoying squeal coming from the front right of my car. any time i turn the wheel or go over a bump it squeels. i frist thought it was either the strut or coil over. so i replaced both of those and while i did that i realized that the upper ball joint was shot so i replaced that as well. well the squeel went away for a week or so and now it's slowly coming back and getting worse and worse as i drive it more. it doesn't matter if you're moving or sitting still if you turn the wheel or push down on that side of the car is squeels. i'm out of idea's as what it can be can anyone please help me out?
p.s. it's not a belt either
oh yea and it's a 95 gsr
just had some one suggest the sway bar bushing that connects to the body. any idea if that could cause this problem?
no it's not the brakes. the sway bar thing is just what someone told me to check out. when i get time i'm going to tear into it and check all th bushings and also someone said to also check the lower ball joint on it as well they had the same problem on there teg and that was it
