EG w/d16y8 help
Aight i swear i searched and nobody had a similiar problem like mine. I just dropped a d16y8 in my 94 Si and everything is all good except when i first start in the morning or after its been sitting for a while. I start it the rpms go up like normal then they drop back down and the car shuts down. I turn it back on but i give it gas so it wont die and i have to drive it out until it gets to normal temperature then the car is fine. SOmeone help me out
Aight so i also figured when i try to run first thing in the morning it stalls out bad like if i press the gas pedal it chokes and u can hear a lil pop i have put way more clutch than gas for it to move
only if im stopped but if i try to drive it so the temperature goes up but it stalls out bad i have to put more clutch than gas i think i need a new clutch cuz it doesnt grab on i think like it should.
yo is it freezing cold out there right now, because it might be a problem due to weather. check and make sure you have all the right fluids for the season... sounds dumb but i have heard of the problem before due to weather
no not really a weather issue but can i change the tps from another throttle body or do i have to change the whole thing? Because i changed the throttle body but maybe the tps isnt good on the one i just put on
try to clean it first or if you have one laying around........., check your vacuum hoses as well,or even your fuel filter. i delt with every problem on my own 98 civic... I went from dx to ex and had every fuken problem... and did a job for a homie and got a b20 for free... sooooooo... but anyways let me know what next step you wanna try if doesnt fix, try to clean out the injectors as well
yo i also have a bunch of stuff for the eg.. 99 gsr wire harness.. direct plug and play to the eg. also have vtec head. and also have a tranny. all for d16y8.. i know you live far from cali but maybe we can work sumthing out if those parts arent available to you
https://honda-tech.com/forums/showth...2483147&page=2
sorry try this one alot better
Or maybe kids these days can't think very far ahead.
Or maybe a little from column A and a little from column B.
hey you can do that, that`s cool... But ill probably run circles around you shorty. I guess 30 is the new 16. Or maybe a little of column A and column B... I thought in the country you raced horse carriages, not v-tec motors!!!! You know what that is right.
I sense much banhammer in this one
