transmission pops out of gear
Old Jun 1, 2009 | 09:48 PM
eastbayg's Avatar
Default transmission pops out of gear
i have a 92 integra hatch with a jdm b16a setup. i put on a 95 gsr transmission and now that its gettin hot, it starts to pop out of gear. it only happens in 5th gear no matter what rpm or speed, ONLY IN 5TH. any ideas?
Old Jun 1, 2009 | 10:04 PM
Dead CIVIC's Avatar
Veteran: Army
Default Re: transmission pops out of gear
definitaly maku sure tranny oil is @ proper level
Old Jun 1, 2009 | 10:17 PM
Dedotut's Avatar
the tranny could be just messed up make sure when u put the oil in that u have the car run throgh all the gears somtimes when u take a tranny out the oil left in it makes it stickky so just make sure u do that, integra hatch is a Da 1992 ls/gs/gsr?
Old Jun 2, 2009 | 05:56 AM
joelmatt89's Avatar
does it grind at all or is it smooth shifting, if it shifts smoothly then these guys are probly correct in telling you it's the fluid
Old Jun 6, 2009 | 02:53 PM
eastbayg's Avatar
it doesnt grind at all, im gonna check the fluids tonight. thanx
Old Jun 6, 2009 | 03:07 PM
itsmejto's Avatar
Check your linkage is working correctly, if it isn't shoving it in far enough it will slip out.
Check for warn bushing in the lever and linkage mounting points underneath.
Old Jun 6, 2009 | 05:27 PM
SLO Sol's Avatar
shift linkage could be going bad.. my 95 teg had the same problem
systemoverload
Jun 2, 2006 10:50 PM
DC24jooo
Jul 6, 2004 08:46 PM
AznInvasion
Aug 24, 2002 06:15 AM
TypeSH
Jun 9, 2002 12:00 PM
