JDM GSR TIMING BELT AND WATER PUMP
Would someone be able to tell me the proper part numbers for a timing belt and water pump for a "jdm" gsr B18C.. its an obd1 motor. i bought the motor from Hmotors and wanted to replace this before the install.
The reason I ask is because I was doing the TB and WP today and when I removed the belt I noticed the part numbers didnt match to what I had. I went ahead and pulled the water pump and there was dowel pins in the pump on the motor but not on the new one.
I soon realized that the guy from honda had given me 99-00si or delsol(b16) pump and belt. I must have not been clear enough to him on what I needed. The parts I think I need are off a 94-95 delsol, which is obd1 as well (tbelt- 14400-pr3-004) (WP 19200-p30-003)
The part thats getting me is that on the belt I removed the part number is 14400-p72-004
which is different than the 95 delsol belt... and doesnt even come up on honda/acura parts stores.
Any help/advice is much appreciated. Thanks in advance!
I dont think its that... and besides that my motor must be pre 95 if its OBD1
14400-PR3-004--------93 gsr belt
19200-P30-003--------93 gsr water pump
14400-P72-014--------95 gsr belt
19200-P72-003--------95 gsr water pump
14400-P72-014 --------98 gsr belt
19200-P72-013---------98 gsr water pump
THE BELT I REMOVED IS PART NUMBER- 14400-p72-004
Didnt see any part number on the water pump.... any ideas?
14400-P72-014-------94 gsr belt
19200-P72-003-------94 gsr pump
WHY IS THE BELT I PULLED OFF PART NUMBER 14400-P72-004????
That part number doesnt come up on honda or acura sites.
my car is a 91 crx... the motor is an obd1 JDM GSR, from Hmotors. just stumped on why this Honda belt and part number doesnt come up anywhere.
ever dawn on you that the part numbers may have changed? kind of like how the obd1 oil pumps are not made anymore since the obd2 style work on all of them. besides the jdm and usdm engines are nearly identical short of the compression and in obd2 the cfs sensor.
I have a B18C 97' (ITR), using a GS-R water pump works fine. You want anything with a 22 Teeth.
My new water pump I bought for my B20VTEC Turbo I'm building:
GS-R
Belt: 14400 P72 014
Pump: 19200 P72 013
When you go to honda, if they use the same computers we used, they can't see Acura Parts. We would have to call up Acura and ask them... Kinda lame, but what can you do?
-B
jun_spek
Jun 21, 2009 01:18 AM
JDM DC2
Aug 29, 2002 11:39 PM
14400p72014, 19200p30003, 19200p72003, belt, gsr, gsrpartstiming, install, jdm, motor, p72, pump, teeth, timing, usdm, wather
