SWAPPING OUT Y7 NEED HELP WITH ECU!!!!!
so i posted something yesterday but i need to revise my question, k i got a 1999 EK coupe DX engine died, i bought a y8 out of a 1999 Acura EL with engine harness, but im not sure what ECU to use or what i can do with that i know for a civic i should get a OB2DB out of a EX but will that work with the engine harness that the Y8 came with from the EL?????? im getting a bit confused with this all
i live in Canada BC lower mainland so if anyone has something pls help !!!!!!!!!!
Both cars are a 99 which means both are obd2b. Use the ECU made for the motor you are putting in. Both ECU's will plug right in to either harness as well.
dxcivicsi
May 31, 2009 08:15 PM
alacard
13
Jun 28, 2006 09:47 PM
