Spun rod bearing
Old Jun 1, 2009 | 05:43 PM
hondajen's Avatar
New User
Default Spun rod bearing
I just bought a 93 civic and it now has a rod nock. I pulled the engineand discovered it has a spun rod bearing. there is little to no damage or scarring. I just bought new acl main and rod bearings, my question is do i need to get new rod and crank or do you think i would be able to get away with using the same parts
I also got new oil and water pump, timing belt and tensioner and all new gaskets
Old Jun 1, 2009 | 05:53 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Spun rod bearing
I would recommend getting all new rods and crank.
Old Jun 1, 2009 | 06:20 PM
rotten's Avatar
Get new rods and crank. Unless you get really lucky you won't be able to use ACL bearings. YOu can try to find a matched crank/rod set that has normal clearances, and also fits your block using ACLs. Otherwise you'll have to order custom matched bearing set from Honda, plastigauge to make sure they have correct clearances.
Old Jun 1, 2009 | 06:53 PM
PyroProblem's Avatar
If you spun a rod bearing, chances are the crank is shot too. Only way to tell for sure is to measure it. You could always find a cheap used single cam and put all your new parts on it.
Im sure some of the local speed shops have some laying around...
hardcore97
Apr 23, 2015 07:55 PM
jakscivic
Feb 21, 2013 08:27 AM
hondajen
Jun 1, 2009 06:09 PM
v4lu3s
Jul 26, 2004 11:25 AM
Sonny
Jun 12, 2002 07:24 PM
