Quick ? Will a B18C1 tranny fit a B18A1 engine?
Old Jun 1, 2009 | 03:55 PM
B18CYAAA's Avatar
Default Quick ? Will a B18C1 tranny fit a B18A1 engine?
As stated, B18C1 tranny off a 94 GSR, and a B18A1 off a DA. thanks
Old Jun 1, 2009 | 04:00 PM
mdhimes's Avatar
Default Re: Quick ? Will a B18C1 tranny fit a B18A1 engine?
The transmission/motor combination will bolt together just fine but be aware that 94+ integras have hydraulic transmissions. Pre 94 integras have cable transmissions. In other words don't try to put a hydraulic transmission in a DA without a conversion kit.
Old Jun 1, 2009 | 04:04 PM
taggart_lumpy's Avatar
also if your car is a 90-91 5 spd you will need the clutch assembly for the gsr tranny as it has larger splines on the input shaft
Old Jun 1, 2009 | 04:09 PM
B18CYAAA's Avatar
good info, it's not for me I'm selling the tranny.
Old Jun 1, 2009 | 06:12 PM
da.nizzle's Avatar
Pre 92*
Integras got hydro trannys in 92.
All b trannys are interchangeable as long as theyre both hydro or both cable.
And you can actually run any b trans with any b car. Just may have to get a conversion kit.
ali_232
Apr 8, 2007 11:03 PM
Honteggie
Apr 6, 2005 08:37 AM
BseriesHatch
Nov 13, 2003 08:27 AM
SL!M
Aug 30, 2003 09:28 AM
black-hatch
Feb 14, 2003 03:48 PM
