how to remove resude from Aircraft Striper?
Old Jun 1, 2009 | 11:28 AM
Charlie Moua's Avatar
Default how to remove resude from Aircraft Striper?
I'm painting my valve cover.
I did so search already but there are just too many.
Alot of them show what to use, but seem to skip out on a step.
I used "aircraft striper" it came off great but some areas are left with this white resude.
How do i remove it?
Thanks.
Old Jun 1, 2009 | 06:35 PM
shocker911's Avatar
Default Re: how to remove resude from Aircraft Striper?
did you wash it with water??? put a glove on and rinse with water and rub it with your gloved hand
Old Jun 1, 2009 | 06:50 PM
Cyanide Jello's Avatar
Water, homie... Then I'd clean it real good with some denatured alcohol or lacquer thinner... Or if you're cheap, Windex works good too...
Old Jun 2, 2009 | 07:51 AM
I'll try windex.. it should rub right off right? not like i have to brush it off with steel brush?
Old Jun 2, 2009 | 10:32 AM
shocker911's Avatar
it should just come off...maybe get a scotch brite if it dosent wanna come off
Old Jun 2, 2009 | 12:33 PM
I second this motion...
Old Jun 2, 2009 | 01:24 PM
bakertime's Avatar
I just hosed mine off and then rinsed with dish soap/ warm water afterward.
Old Jun 3, 2009 | 06:45 PM
NACvicSi's Avatar
I just hosed off then a quick run over it with some 800 grit sand paper and wipe down with alcohol.
Old Jun 3, 2009 | 07:18 PM
danthemang3's Avatar
if your going to be painting it go to your paint shop and get wax/grease remover. nothing else.
4dek
22
Dec 24, 2010 02:23 PM
ejLday
Detailing
Mar 25, 2009 08:54 PM
lude98SH
Paint and Body
Mar 10, 2008 03:16 PM
1ntegrat10n
Feb 15, 2007 08:24 PM
I Want An Si
Jul 22, 2003 08:36 AM
