Water in engine... is tranny still good?
Old May 31, 2009 | 12:17 PM
B18CYAAA's Avatar
Default Water in engine... is tranny still good?
Someone filled my teg's engine (B18C1) with water. Obviously, the engine is now worthless. Is the tranny still good? Or is it also worthless? Also, what is the code for the tranny y80 or something like that?
Old May 31, 2009 | 12:26 PM
stevenDAtegra's Avatar
Default Re: Water in engine... is tranny still good?
why did they do that? Your transmission will still be good unless they filled that with water. Then the bearings may have gotten a little worn. The oil seal on the crank probably stopped water
Old May 31, 2009 | 01:02 PM
blac00si's Avatar
This is the dumbest thing i have heard in a long time.
Old May 31, 2009 | 01:05 PM
sayyoooon's Avatar
Must have been a crazy ex-girlfriend.
Old May 31, 2009 | 02:05 PM
MeathooK's Avatar
Chances are the tranny's fine, like somebody posted earlier...unless they jacked it up, drained the tranny fluid, then put the plug back in, and opened the fill plug up and put water in it...which is very unlikely. Not to mention the rear main seal would have stopped water from getting into the clutch casing.
Old May 31, 2009 | 02:14 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
you know, if you havent run the car too long, there is a chance the engine is still good...
Old May 31, 2009 | 03:12 PM
ruffrhyder's Avatar
This is not as bad as a customer that I had come in, asked why his car started overheating immediately after he did a radiator flush. He had a 2004 Chevy Silverado, so it requires DexCool coolant which is a pink/orange color. Well, instead of asking someone at the automotive store for DexCool, he bought the first pink/red gallon of fluid he saw on the rack. Turns out he filled his radiator with Valvoline Maxlife motor oil.
Old May 31, 2009 | 03:26 PM
blac00si's Avatar
OMG hahahahaha
Old May 31, 2009 | 07:31 PM
B18CYAAA's Avatar
haha... but I didn't fill My engine with anything but Mobil 1.
Old May 31, 2009 | 07:55 PM
CompanyFlow's Avatar
Why dont you just drain the oil and crank it with the plugs out in the sun.
Old May 31, 2009 | 07:57 PM
B18CYAAA's Avatar
Once it's filled with water doesn't it oxidize and ruin the engine?
Old May 31, 2009 | 08:00 PM
Where did you get water into your engine?
into the intake manifold?
Take plugs out and fill cylinder walls with water?
into oil?
Old May 31, 2009 | 08:14 PM
B18CYAAA's Avatar
"filled with water" A gallon or 2. When I drained it it overflowed from my oil pan. All I wanted to know was whether that water could enter the tranny. Sounds like it can't.
Old Jun 1, 2009 | 05:11 AM
redflaredcrx90's Avatar
did you check to see if you head gasket wasnt going bad.
Old Jun 1, 2009 | 02:16 PM
elfenguard911's Avatar
thats just odd...i agree its literally impossible for anything to had gotten into the trans. the motor and trans have no fluid exchange plus you have several heavy duty seals,flywheel ,clutch and input shaft seal(or flexplate,torque converter if its auto) .you sure the headgasket DIDNT blow?! check the antifreeze level.
Old Jun 1, 2009 | 02:21 PM
99civicsiguy's Avatar
im thinking the engine could be still good, even with head gaskets blown engines can still be good with a proper flush and a new gasket. ideas?
Old Jun 1, 2009 | 02:30 PM
your right the only real way to know is disasseble the motor to find out the exact condition of the bearings.
Old Jun 1, 2009 | 02:46 PM
paton5g's Avatar
I want to know how someone filled his engine with water. Pour it all down the oil fill cap? How did they pop your hood? Do you not lock your doors? Do you give copies of your car key away?
Old Jun 1, 2009 | 03:46 PM
trifenix's Avatar
if you dont have a hole in your block (yet) u can try to clean out the water let it dry and change the oil a couple times, and fire it up.
B18CYAAA's Avatar
Car was on blocks in my driveway after an accident. Door/window smashed and could access hood lever. Could get into the engine bay easily. So if the bearings are good the engine is good? That significant amount of H20 won't oxidize the camshafts and everything else. And the headgasket was fine before this.
Old Jun 1, 2009 | 08:37 PM
gotta get technical here. if they truly FILLED the motor with water then oxidation wont grow rampid til drained and if you had cranked the motor then the build up of pressure will try to relieve itself through the weakest point which could be through the headgasket if it has the slightest bit of warp. but i guess it would much easier go through the spark plug ports or any other gasket.
its one of those no choice take it apart and see i had found one of my projects in a open field when the shop i had it at screwed me over exposed engine no exhaust but had manifolds outside for 4 months during the summer and was oxidized near the open ports primarily no deep damage though it already had wiped bearings it was caused by the rain.
Old Jun 2, 2009 | 09:48 AM
B18CYAAA's Avatar
Thanks 911 good info.
sd619jef9
Apr 20, 2011 09:32 PM
qtcivicturbo
Jun 6, 2008 05:36 PM
punkracer
Jan 11, 2006 11:48 AM
ridiculus
May 23, 2005 09:27 AM
GZERO
Oct 23, 2002 12:30 PM
