RPM bouncing in park
Old May 30, 2009 | 04:41 PM
jaffaccord's Avatar
New User
Default RPM bouncing in park
I turned my 2002 Accord EX V6 on and the tach bounces up and down to around 2000 rpms. I pressed the gas, thinking that maybe the pedal got stuck a little bit, but it didnt stop. I turned it off, and then immediately tried to turn it back on and the tach was bouncing up and down again to 2000 rpms. It was working perfectly earlier today, can anyone tell me whats wrong?
Thanks in advance.
Old May 30, 2009 | 07:01 PM
aasarsak's Avatar
Default Re: RPM bouncing in park
vacuum leak
use the search function. It is incredibly amazing, wonderful, and powerful.
Cheers.
Old May 30, 2009 | 07:13 PM
Targa250R's Avatar
be professional
When the engine is cold, check the coolant level in the radiator (not the overflow bottle). If the coolant level is low, add antifreeze until the rad is full to the brim.
If the coolant level is fine, the problem is the IAC rotary valve. Common problem with J-series V6es. If the Check Engine light comes on with code P0505 stored in the ECU, then it's definitely the IACV.
gitarman2
Jun 13, 2013 03:38 PM
AdamBl
Apr 27, 2011 07:41 PM
jdowen2
Oct 22, 2010 12:30 PM
Fat4ULEV
Nov 1, 2009 11:09 AM
H22A_MD
May 27, 2006 04:01 PM
