Catch can H22a turbo
Im boosting my civic h22a with 8-9 psi and im trying to find some good pictures or diagrams on how to hook up my catch can.
I know there is alot of info about this in the forum, but in most of the threads the pics dont come up, I dont know why and that makes it hard to be 100% shure..
There's also to much different informasjon, so i am confused.
My can has two inlet's on the top and a drain at the bottom. i beleeve this one does the jobb as it's just a street car.
I dont have a "black box" just a short hose from the back of the block to something thats beetwen the oilfilter and the block, is that thing a diffrent type of black box or..?
My valve cover has a outlet on drivers side with a oneway check valve that's conected to the intake manifoild and a open one on passenger side. I also have a crank filter available.
It would help me allot to get a complete explanation of how to hook it up, im tierd of reading and searching, it just comfuses me. also a couple of pictures tells allot.
Run the breather nipple from the VC to the can, and get a fitting to replace the pcv and run that to the other inlet on the can, then have it drain to the oil pan as the h22 doesn't have block fittings.
ok thanks but, Im still comfused and not 100% shure where the pvc comes out..
Is it the hose to the right of the oil filter and does it go from there to that ring(dont know what it is) between the filter and block? Btw this is a JDM i it makes a diffrense. What do i do with the PCV valve on the drivers side? just leave it?
