Transmission & Drivetrain Gearboxes, Differentials, Clutches
Kaaz Diff... need some help with it
Old May 29, 2009 | 07:09 PM
slambedcivic's Avatar
Default Kaaz Diff... need some help with it
Ive got a KAAZ diff that the guy said locks up in turns. Im not really familiar with one way and 2 way LSD's. Ive had it for years now. Never really ventured into researching it. Its from a cable LS trans. Is there anyway to even identify wether or not its a KAAZ?
Old May 29, 2009 | 07:54 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Kaaz Diff... need some help with it
take a pic would help ALOT.
A Kaaz or other clutch style LSD can lead to a push under power coming of the apex of a corner.
I loved my Kaaz.....till I broke it
Old May 30, 2009 | 02:22 AM
I was hoping you or blown90 could help me out. Ill take a pic of it as soon as I get back off of the water this afternoon. I really appreciate it. Ill PM you when I get it up.
Thanks again.
Old May 30, 2009 | 11:04 AM
Old May 30, 2009 | 01:47 PM
577HondaPrelude's Avatar
No OEM spedo gear, the grooves are in the LSD case. The FD ring gear is mounted with right hand bolts. Looks like a kazz to me.
Old May 30, 2009 | 02:13 PM
Holy cow man! How did you see the right hand threaded bolts? I thought it was rather unusual that they werent reverse thread. Kudos to you sir!
Old May 30, 2009 | 02:16 PM
Now that youve proven how smart you are.... Why would this LSD seem to be locking up at all times on the customer? Will this diff only work in a cable trans?
Old May 30, 2009 | 03:29 PM
Mista Bone's Avatar
D Tranny Guru
because that is want a Clutch LSD does.
Try running Pennzoil Synchromesh and 1/4-1/3 tube of Posi additive.
Old May 30, 2009 | 03:31 PM
will this diff work in a hydro case?
Old May 30, 2009 | 03:39 PM
Mista Bone's Avatar
D Tranny Guru
90-01 LS/B16 are the same diffs.
Old May 30, 2009 | 03:49 PM
thank you!
stmotorsports
Jul 20, 2016 04:08 PM
DOHCarp
Oct 21, 2010 08:59 PM
ramco
24
Oct 24, 2009 05:39 PM
FreaQ
10
Mar 12, 2009 08:34 AM
SI_frankenstein
Oct 21, 2007 02:06 PM
