LS vs. GSR ::: Catalytic Converter / Exhaust Lengths
Old May 29, 2009 | 03:12 PM
LOVEthatDC2's Avatar
Default LS vs. GSR ::: Catalytic Converter / Exhaust Lengths
I'm getting a gsr engine ready to swap into my ls ... and the ls needs a new cat to smog.
Am I going to run into any issues with the cat / exhaust when I swap the gsr engine in?
Do I leave the ls header on the gsr block? Is that even possible? ThankS!
Old May 29, 2009 | 05:29 PM
Default Re: LS vs. GSR ::: Catalytic Converter / Exhaust Lengths
anyone?
Old May 29, 2009 | 08:29 PM
310Integra's Avatar
just get the ls header if you need it and ls cat for your car,, no need for gsr, unless you like to change the b-pipe. or you can get 00-01 gsr cat same size cat as 94-01 ls but i belief there the same as ls.
Old May 29, 2009 | 08:32 PM
310Integra's Avatar
and if you need to confirm what i said, look it up on team-integra and there's a diagram there too. i've look it up before when i bought the wrong b-pipes meaning my cat was too short(gsr) ls cat are about 3 inches longer. so i did my research but it be better if you look it up to be sure..
Old May 29, 2009 | 08:51 PM
lilo_goki's Avatar
you can just use the ls cat and ls header, it'll be easier and there's nothing wrong with using it, the gsr cat is longer than the ls cat i believe, and the ls header is longer than the gsr header, the flange is also off by a little, so gsr and ls won't fit right.
Old May 30, 2009 | 10:10 PM
cool thanks for the info fellas
I will leave the ls header and cat on until I can find a gsr oem header and 'test' pipe haha
F_dub7
Jan 23, 2010 06:28 AM
jdmxxdc2
Jan 13, 2005 11:26 AM
DsBananas94LS
Aug 8, 2004 05:48 PM
HybridHatchC1
Jan 10, 2003 09:25 PM
wdyno
Mar 14, 2002 04:41 AM
