Aluminum Tig Help
try bumping the ac balance up to 7.5 - 8
as for holding the pieces i usually have someone there to help so i have them hold it
or i prop them up against other items then tack
I sometimes use that green masking tape to hold everything in place while I tack it, especially charge pipes. As long as it's a few inches away from your tack it's a pretty clean way to hold things together.
Also, keep a bunch of steel and aluminum blocks around to prop stuff up with. I have a few that are around 1" x 2" x 4" that I milled square and some other ones of various sizes and shapes. they make great heat sinks too if you are welding small parts.
to get the part in place i just no filler tack it, then adjust it and then do a filler tack, where and how many depends on the part.
tack it by getting both pieces molten and try to join that puddle/dap filler in the middle of each "half puddle"
Not a bad idea. Does it have much strength? The green 3M masking tape can hold quite a lot in tensile. I always wipe every thing down with a solvent after mock up anyway, but yeah If you get masking tape hot it gets gooey. The green stuff does smell like pineapple when it burns though...which is nice
I have tried to join with no filler but my joints are corner to corner and each piece just melts away. Maybe I'm doing it wrong? The second method I can't do because I only have 2 hands. Hard for me to hold the pieces together and dab filler in.
I did it by propping items against it tacking them, then bending them to the angles I need. It works but I was hoping there was a better way to do it.
it is stronger than automotive masking tape but it doesn't have a pineapple smell.
sdubfid while you are learning use 1/16" filler to tack, as for as technique heat up one side until it wets then bump the power a little while simultaneously moving to the other side and adding filler, if its a closed corner joint start your heat on the overlapped side. you'll get it just takes practice like everything else.
I've got some of those AL magnets. $100 a set. All sales are final.
To tack AL with no filler you have to hit it with a lot of amps really fast and then let off just as fast. They don't typically hold really well so I go back over and retack with filler before welding.
Skeero
Welding / Fabrication
12
Dec 28, 2011 09:20 PM
cilvia
26
Feb 7, 2006 06:48 PM
