newbie question on engine
Old Aug 19, 2002 | 02:14 PM
ragez's Avatar
Default newbie question on engine
So I have a 90 Accord LX and my engine seem to have a problem. It always shaking whenever I stop and the tech guy warn me not to turn the air condition on or it would break. it's a 4 speed engine.
Old Aug 19, 2002 | 02:18 PM
greensleeper's Avatar
Default Re: newbie question on engine (ragez)
engine mounts?
Old Aug 19, 2002 | 02:23 PM
Razor's Avatar
rear engine mount, most likely
Old Aug 19, 2002 | 02:28 PM
ragez's Avatar
thanks!
Old Aug 19, 2002 | 03:47 PM
m0t0rhead's Avatar
Default Re: newbie question on engine (Razor)
I have the same thing with my new energy suspension front motor mount bushing insert ever since I put it in. No vibration at all before that... and it's REALLY bad when I turn the A/C on and the radiator fan comes on.. like.. super intense.
Old Aug 19, 2002 | 04:18 PM
ragez's Avatar
Default Re: newbie question on engine (Escobar)
i know. But I have to get use to it. Since summer almost over and I can't afford any money right now.
Old Aug 19, 2002 | 05:26 PM
Ideal's Avatar
yes, i guranntee its the rear motor mount, i had it replaced, 460 parts and labor, if i only i had the tools to do it myslef, 200... so it wont harm your car for a while, but eventually it might start to screw up your other mounts... so i would have the dealer check, just the mounts....
jon
Old Aug 20, 2002 | 12:20 AM
Accord94DX's Avatar
Default Re: newbie question on engine (Ti1301)
one right on the lower crossmember, to the left of your header. Two on either side. One in the rear under your intake manifold.
Old Aug 20, 2002 | 12:22 AM
ArchAngel Sabastian's Avatar
New User
Default Re: newbie question on engine (Accord94DX)
on 5th gens maken power the rear has a habit of tearin up ****..
Old Aug 20, 2002 | 12:24 AM
Accord94DX's Avatar
Default Re: newbie question on engine (Sabastian)
5th gens? Makin power? BWHAHAAHHAHAAHHAHAHAHAHAHAHAHAHAHAHHAHAH!!!! ima go sleep.
Old Aug 20, 2002 | 12:27 AM
New User
shadup B
Old Aug 20, 2002 | 05:07 AM
check out these tools' post times? you guys stay up late, hit the rock pipe, and go crazy on the web or what?
Old Aug 20, 2002 | 06:44 AM
Gennady's Avatar
New User
Your engine wont break, it will just **** you off.
Old Aug 20, 2002 | 06:57 AM
carolinaACCORD's Avatar
i dont know about on the 4th gen mounts, but the rear mount on the 5th gen 4cyl.
is a electronically controlled mount.at idle, a solenoid opens a valve in the mount and lets fluid flow between the chambers. if any part of that mount system goes bad, the idle will be rough.
does the 4th gen have this same setup?
i thought of this when you said it's rough when you stop.
Old Aug 20, 2002 | 07:04 AM
Default Re: newbie question on engine (carolinaACCORD)
I had no idea...
Default Re: newbie question on engine (greensleeper)
I had no idea...
yeah, i dont know about the 4th gen though.
Paul 631
Jan 5, 2013 07:18 AM
shewit08
18
Jun 21, 2010 05:34 PM
sealz
Acura TSX
Mar 15, 2008 10:21 PM
ajth87
Apr 10, 2006 04:05 PM
SkylineGTR
Apr 6, 2005 10:33 AM
