94-01 integra driver window motors all the same?
Old May 29, 2009 | 09:04 AM
jayare05's Avatar
Default 94-01 integra driver window motors all the same?
my window motor in my driver door **** the bed and im wonderin if the motors and regulators are all the same? im pretty sure they differ between 2 and 4 doors just not sure if the part changed between the years.
Old May 29, 2009 | 12:23 PM
jayare05's Avatar
Default Re: 94-01 integra driver window motors all the same?
bump
Old May 29, 2009 | 01:32 PM
racebum's Avatar
they are not the same. i have no idea when they changed but i have seen both cable driven windows and the gear driven. i THINK 94-97 is gear and somewhere after that is cable. i know my 97 is gear and i also have a door downstairs that's cable. actually. if any members around my area want a straight white door with glass pm me. it's yours for free
Old May 29, 2009 | 01:43 PM
jayare05's Avatar
ahhhh.. can anyone verify this? im tryin to buy a window motor online asap and dont want to order the wrong part. im lookin into pickin up a used 1..
Old May 29, 2009 | 01:50 PM
racebum's Avatar
you should just get one for the year of your car. since you have a 99 which is a year i'm not totally sure of; you should just pull your door panel and look to see if you have a cable driven window system or gear. it's pretty obvious when you glance at it.
Old May 29, 2009 | 04:24 PM
TunerN00b's Avatar
My 2000 GSR windows are gear driven, not cable.
Making a wild guess, but did the RS come with manual windows? That could be the source of the cable driven setup if so.
Old May 29, 2009 | 05:45 PM
racebum's Avatar
these were power. i actually scammed the autoparts store with the motor. i bought one for my car, installed it then returned the cable motor
the easiest way i can think of for the op to get this done is to look at his then make sure he's buying the same one. the gear ones have just that, a gear on the side. the cable motors have two cable exits out the side and no gear. very easy to tell the difference
TechyJR
Sep 7, 2016 05:08 PM
HFP-EP3
May 25, 2008 02:08 AM
