car stalls between 2k-3500k rpm for about a mile when first heats up??? HELP
Old May 28, 2009 | 06:58 PM
tymbo's Avatar
New User
Default car stalls between 2k-3500k rpm for about a mile when first heats up??? HELP
Well i am new to the board as far as posts. I just did a clutch install and now when i start my car it will idle fine, and drive fine until the motor starts to heat up. The motor pulls like before and then. . . . between 2k-3500k RPM the car act as though it is starving for gas. I will do this for about a mile or so. Then the rest of the trip, weather it is 5 miles or 100 miles it wont happen again. But if i stop and the engine is turned off, even if it is warm it will still do the same thing. I cleaned off the contacts on the cap and rotor on the distributor. Replaced the fuel filter. check and cleaned off all grounds. checked vacumn hoses. Nothing, still doing it. Also the alternator is working correctly, reset the ECU and check all the wiring. the really f'ed up thing is the is nc Check engine light. Please help me with this problem. I have looked at the Haynes manual and says nothing about the problem i am having. Thanks
Old May 28, 2009 | 10:25 PM
sixfourkiller's Avatar
Default Re: car stalls between 2k-3500k rpm for about a mile when first heats up??? HELP
if it start to happen after u install your new cluth that would be the first place i would start to look for problem maybe something wasnt set right..
iangon
Jan 22, 2010 08:33 AM
Vtec_Dude
Feb 17, 2008 06:38 PM
redlines4us
Nov 18, 2005 07:37 PM
H23 Power
Jul 25, 2004 08:22 AM
yorktonite
May 23, 2003 09:01 PM
