Spark Plugs for '96 Accord
Old May 28, 2009 | 01:10 PM
nfiniti's Avatar
Default Spark Plugs for '96 Accord
Looking for help on oem spark plugs for a '96 Accord LX 4 door.
I know the oem part# is 98079-5514G, and the oem NGK is ZFR5F-11. My question is, does it matter any if I install the ZFR6F-11 instead (i'm heavy footed so I speed a lot, so I'm thinking heat range of 6 will dissipate the heat better)???
Also, I looked on denso's webpage and it referenced KJ20CR-L11 as its oem, but every other web site states denso oem as KJ16CR-L11. So, which denso part# is the correct one, and does it matter any which one I install?
thx
Old May 28, 2009 | 10:22 PM
nicolaselias's Avatar
Loved
Community Favorite
Default Re: Spark Plugs for '96 Accord
In the USDM models the 5f was OEM but the JDM engines (2.0L) the 6f was reccomended as the engine runs higher compression..
I would just go with the 5 considering your engine (f22b2).. as far as I understand, heat range wont affect heat dissipation, NGK has a lot of his information on their website
If you want some good advice, spend the 80c more per plug and get the NGK G-Power platinums ZFR5FGP instead of the stock coppers... will last longer and at such a small difference.. why not?
Old May 29, 2009 | 06:45 AM
BBallz24's Avatar
email NGK. They will recommend the best plug for your setup.
lil_williams
Jul 27, 2007 12:45 PM
CaymanNational
Honda S2000
Mar 12, 2006 04:49 PM
clutch33
23
Jul 19, 2004 12:21 PM
HondaGus
Jun 4, 2004 06:08 PM
Knight2000
Oct 11, 2002 05:14 AM
