I got cams. What else do I need?
Old May 28, 2009 | 11:06 AM
DOHC 4 life's Avatar
New User
Default I got cams. What else do I need?
I just got Crower stage 3 cams for my b18a1. Is there anything thing else I need? Like valve springs or anything?
Old May 28, 2009 | 11:10 AM
Ruben19's Avatar
Default Re: I got cams. What else do I need?
what compression ration r you running. cams are too big if you r stock. you must use dual valve springs & retains. also tune, header,
Old May 28, 2009 | 12:12 PM
rebar71's Avatar
HONDRETTI's Avatar
i would highly recommend you upgrade your entire valvetrain with running those cams, considering you will be visiting 9k with a tune. dont forget to tune. you may also be interested in upgrading your intake and exhaust system. good luck.
Old May 28, 2009 | 10:30 PM
sixfourkiller's Avatar
wow man u starting out big to go stage 3 cams u going to need to upgrade alot of other part so u can used those cam without blowing something else from your engine. first get better valve and spring and retainer to hold those cams.
Old May 29, 2009 | 02:14 AM
THE GUY's Avatar
Not to be confused with "THE MAN"
HONDRETTI why would he be at 9k? I had a built LS a while back with 404's and never went to 9k. big cams don't always equal revving very high.
OP-, spring, retainers, IM, injectors possibly, better header and larger/better flowing exhaust, and most importantly a TUNE. REad the All motor forum and speak with people in there. Good luck bro and enjoy it.
Danny Fallas
Feb 13, 2013 03:30 PM
b19coupe
Jan 20, 2013 06:03 PM
TurboTeG4
Dec 15, 2003 07:17 PM
LiveWire401
May 9, 2003 09:32 AM
SebAyatollah
12
Feb 27, 2003 03:11 PM
