Suspension & Brakes Theory, alignment, spring rates....
Prelude camber adjustment... chassis tech adjustbale UCA
Old May 28, 2009 | 11:05 AM
kornerk12's Avatar
Default Prelude camber adjustment... chassis tech adjustbale UCA
I have seen the adjustable balljoints for 5th gen preludes however recently I recently saw that chassis tech offers an adjustable UCA for the 5th gen prelude, it does not specify SH or base so I am assuming it only works for the base. Has anyone used their products ? Also any opinions on the adjustable balljoints ?
Old May 28, 2009 | 04:51 PM
kornerk12's Avatar
Default Re: Prelude camber adjustment... chassis tech adjustbale UCA
bump
Old May 28, 2009 | 05:08 PM
kornerk12's Avatar
http://cgi.ebay.com/ebaymotors/97-01...Q5fAccessories
Old May 28, 2009 | 05:42 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Why would the SH front UCA's be different from the base model?
But really a camber kit isn't needed. Just get an alignment after your ride height is finalized, getting the toe set to factory specs, and your tires will be fine.
Old May 28, 2009 | 05:51 PM
TunerN00b's Avatar
The LCA is, you sure the UCA isn't? (I forget the exact details, was interested in SH 'ludes once upon a time ago.)
Old May 28, 2009 | 05:55 PM
TunerN00b's Avatar
Found this:
https://honda-tech.com/forums/honda-prelude-4/5th-gens-base-vs-sh-762014/
Originally Posted by linked thread
front suspension is different on the SH (biggest thing people dont realize). the geometry is different (specially designed to reduce torque steer)
...(skipping stuff)...
There are actually quite a few differences between the base and the Type SH suspension, The springs are not the same. The type SH springs are a little taller. The struts are different as well, the base where the spring is perched sits lower on the Type SH, hence the taller spring. It results in a little firmer spring rate than the base. Lets not forget to mention the front knuckles are different, the raius rods, the front trailing arms, and the roll bars are a couple of millimeters thicker than the base front and rear.
I think he meant LCA instead of trailing arm for the front. But, I don't really know what the truth is here.
Old May 28, 2009 | 05:57 PM
Community Builder
hmm Base and SH do have different part numbers, but they're both exactly the same price at San Leandro Honda Parts.
Old May 28, 2009 | 06:01 PM
Community Builder
Oh wow, front suspension is COMPLETELY different between base and SH models. Base has a fixed radius arm attached to the LCA, while the SH has a movable radius rod that attaches directly to the knuckle. The knuckle has 2 lower ball joints.
Base front LCA:
SH front LCA:
But back to the original question, I'm not sure if those adjustable UCA's would be compatible with both base and SH model Preludes.
Old May 28, 2009 | 06:11 PM
TunerN00b's Avatar
I'll never understand Honda front suspension design.
Is it just me, or does the SH suspension look like bushing #10 should be turned 90*, putting bolt #18 horizontal, and allowing the bushing to rotate during suspension travel? As it is, it looks to require bushing deflection to allow any suspension motion... Certainly they rotate vertically during suspension travel more than they rotate horizontally from steering (with 2 lower ball joints, the arms must deflect some while turning).
Old May 28, 2009 | 06:19 PM
Community Builder
The bushing would have to deflect no matter which way it's oriented. The same bushing on the Base radius rods have to deflect with suspension travel. That's just how it is unless sphericals are used.
But yeah it seems to me that the Civic/Integra A-arm design with no radius rods are a better design.
Old May 28, 2009 | 06:28 PM
kornerk12's Avatar
well back to the thread at hand, has anyone used chassis tech products or have an opinion on the product ?
Old May 29, 2009 | 08:34 AM
Televator's Avatar
What? Some one made an adjustable UCA for the 5th gen? Hmmm...IDK that adjustable plate looks a little weak... It's thinner and longer than the ones I've seen.
Being able to make adjustments on the fly is useful for people who use their car for varying tasks.
Old May 29, 2009 | 04:50 PM
kornerk12's Avatar
idk if those pictured our the specific ones for the prelude but either way im sure construction would be similar.
Old Jun 5, 2009 | 08:26 AM
kornerk12's Avatar
bump, im really interested in these
Old Jun 5, 2009 | 09:28 AM
Community Builder
I dunno, at $125/pair I would really question the quality of those pieces.
I would say just get them, try it, and if they don't work, throw them back up on eBay again or sell locally on craiglist or something. It's got free shipping, so you won't be out of any money there or anything.
that1hondaguy
Suspension & Brakes
Jun 7, 2015 07:13 PM
2000blacklude
Suspension & Brakes
May 27, 2006 12:26 PM
setiawani
Jan 21, 2002 02:21 PM
