Help with identifying trans FD...
Old May 28, 2009 | 07:11 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
Default Help with identifying trans FD...
I just got a JDM ITR motor, im not sure which year...ive found some odd things with it...the oil pan says P72 instead of 73....the block seems stamped 95, while the head looks like its stamped 96...the tranny is a S80 and is def. a LSD...but im trying to figure out which final drive i have.
The '96-97 came with 4.4 and the 98+ is 4.75 correct?
are there any ways to tell what FD i have other than taking it apart?
Old May 28, 2009 | 11:39 AM
Default Re: Help with identifying trans FD...
no one can even confirm the FD for the years? damn....
Old May 28, 2009 | 12:33 PM
CW-ITR's Avatar
...Easy guy...You have answered most of your questions.
-All ITR and GSR ahve P72 oil pans.
-'96-97 came with 4.4 and the 98+ is 4.75
-S80 with LSD stamp on the tranny means ITR tranny
...I'm not sure about the stamping on the block and head. Perhaps, some close-up pictures will help.
Old May 28, 2009 | 05:45 PM
Tommy_Gunns's Avatar
Drive it and report back what RPMs you are at when you are travelling 60 mph in 4th gear.
Old May 29, 2009 | 04:35 PM
etank82's Avatar
When I bought my first JDM ITR swap, I saw the P72 on the oil pan and freaked out. I was so used to associating P72 with GSR. That along with the ambiguous 'B18C' block code made me think I had paid ITR money for a GSR swap.
Does your transmission have any stamping on it? J4D = 4.4FD and N3E = 4.78FD.
Old Jun 4, 2009 | 04:35 AM
no stamping and i believe at 60 mph in 4th im at 44 or 4600? i think....ill do another solid check and get back...but i think thats right around where it was.
Old Aug 5, 2009 | 05:15 AM
anyone tell what FD i have from those numbers???!??^^^^^^
Old Aug 5, 2009 | 06:00 AM
get RIGHT's Avatar
EASY. Use this calculator http://www.teammfactory.com/gearcalculator.php
Then get in your car and see what speeds you top out in in each gear.
Old Aug 5, 2009 | 07:14 AM
irev210's Avatar
sounds like you have a 4.4FD
Old Aug 5, 2009 | 04:04 PM
Black R's Avatar
25 Year Member
96 spec r motor and tranny
/thread
spintboy
Dec 5, 2007 11:23 PM
stockegsix
Sep 14, 2004 01:38 AM
ek4b18c_r
Mar 24, 2004 11:01 PM
b20a1
Aug 13, 2003 06:07 PM
Apex i ITR
Nov 9, 2001 11:41 AM
