B18c5 to 2.0L Advice Needed
Old May 27, 2009 | 06:39 PM
JDMx2103's Avatar
Default B18c5 to 2.0L Advice Needed
I have a B18c5 with a fully built head but on stock bottom block... i was thinking about boring it out to 2.0L but i need some advice on what pistons, Crank, and Rods to use... will i have enough clearence... i don't want compression to high.. maybe like 11.5-8:1... Or should i just go with the b20 bottom end and b20 vtec it. I wanna use the one that will make more whp/torque. But i'm really interested in boring out the b18c5.. and let me know anything else i might need on boring my b18c5 to 2.0L.
Old May 27, 2009 | 06:49 PM
thabao's Avatar
Default Re: B18c5 to 2.0L Advice Needed
You should just bore. Seems safer than using a non vtec block. I's sure you can use your stock crank and rods, but double check.
get RS machine pistons
http://www.rsmachines.net/pistons.html
If your going 2.0L, get the 84mm piston size. The flat RS ones are the ITR copy. They will give you about 10.8:1 compression. The dome ones should get you in the mid 11.
Old May 27, 2009 | 08:10 PM
I AM WEASEL's Avatar
You can't just bore a B18C5 block to 84mm, it will need to be sleeved first which will run about $1000; so, if you just want a 2.0l and are on some sort of budget, a B20 block will get you there cheaper.
Old May 27, 2009 | 09:56 PM
WheaMyRyceGo's Avatar
I was in your shoes a couple months ago. I decided to get a sleeved b18c block to 84mm with ls crank, k1 carillo rods, and 11:1 je pistons and mount it to my built head. you definitely cant bore ur stock block to 84mm. I recommend sending it off to have it sleeved and built for you. pm me if you have any other questions
Old May 27, 2009 | 10:07 PM
Ausmith's Avatar
Unless you are going to add some compression and larger camshafts (maybe you have them already) personally I don't see all of the effort being worth it. I'd suggest around 12:1 on static compression, 84mm bore, LS crank, a good set of rods, and OEM bearings. You'll also need a good header if you want to maximize output.
lukerc45
Jan 23, 2024 12:34 PM
Junaid K
Jun 6, 2014 10:23 PM
zongetsu
May 27, 2012 05:37 AM
Trey
29
Jul 12, 2011 08:27 PM
Red99CivicSi
18
Oct 15, 2003 11:39 PM
