J&S w/ AEM EMS???
Old Aug 19, 2002 | 12:24 PM
AssPenny's Avatar
Default J&S w/ AEM EMS???
Anybody know if I'll run into any problems running the 2 of them together?
Old Aug 19, 2002 | 12:38 PM
eviltwin's Avatar
Default Re: J&S w/ AEM EMS??? (AssPenny)
are you boosting or spraying?
Old Aug 19, 2002 | 12:43 PM
RATEDR's Avatar
Default Re: J&S w/ AEM EMS??? (eviltwin)
I have BOTH for sale.
J&S with monitor $300 shipped
AEM EMS BRAND NEW $1250 shipped
Old Aug 19, 2002 | 12:45 PM
AssPenny's Avatar
No, just want to be extra careful and get the most that I can out of the B's with out something going pop
Old Aug 19, 2002 | 12:48 PM
Black R's Avatar
25 Year Member
.....double-check this, but I believe the AEM EMS has the same functionality that the j&s has. So the j&s isn't needed like it is with hondata.....
Old Aug 19, 2002 | 12:51 PM
eviltwin's Avatar
dude i wouldnt worry about it. i am looking for a j&s but that is cause i am planning to spray my bitch up and i am going to spray the **** out of it so i would defenitly need it. i had one when my car was supercharged and when i got rid of the supercharge i sold the j&s since i wasnt going to need it for all motor
now i am up to no good and need another one so i can spray a whole bunch of alota naws!!
i mean the only reason i could see someone using it for an all motor car would be if they had really high compression that might cause detonation with shitty pump gas. but if you are 11.5 or under you should be fine with out it. then again this is just my opinion.
Old Aug 19, 2002 | 12:56 PM
AssPenny's Avatar
CTR pistons are next on the list
Old Aug 19, 2002 | 01:01 PM
Austin's Avatar
They can be run together...independent of each other...I prefer the J&S as John has been doing this for quite a while and knows his stuff...not sure how the AEM works as of yet.
Austin
Old Aug 19, 2002 | 01:08 PM
eviltwin's Avatar
Default Re: J&S w/ AEM EMS??? (Austin)
i have yet to see a stand-alone ecu that comes with the same features a j&s come with. if not that would've been the ecu i wouldve bought.
i also agree with them working independantly of each other. they dont work together or off of each other. the j&S detects detonation and retards or advances the timing through the distributor. the j&s has the individual knock sensors that go on the motor.
[Modified by eviltwin, 10:14 PM 8/19/2002]
Old Aug 19, 2002 | 01:13 PM
RATEDR's Avatar
I have those too for sale! $250 for all 4 brand new in box...
naw...im just playing I dont have those. LOL.
Old Aug 19, 2002 | 01:15 PM
eviltwin's Avatar
Default Re: J&S w/ AEM EMS??? (RATEDR)
dudes got more stuff than the homeboy shopping network...
Old Aug 20, 2002 | 08:46 AM
555R's Avatar
which J&S version do you have
I am running Jun3s with JE12.5s and a Jun P28
Im interested as I cant get the car to run very well on pump gas
I think compression may be higher due to the few thousands thick
ceramic coated pistons tops
and the timing is way retarded right now
10 degrees for pump gas 94 octane
Old Aug 20, 2002 | 10:03 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
The AEM does the same thing plus you can have it retard timing based on boost as well. As an added benifit you don't need an extra sensor because it uses the factory one.
All you have to do is read the manual and set up the knock control yourself. IMO, buying any black box to go with an AEM EMS is a waste of money. There's no black box out there that does something the AEM doesn't, in fact the AEM does it all better.
Old Aug 20, 2002 | 10:55 AM
AssPenny's Avatar
Default Re: J&S w/ AEM EMS??? (newt2)
The EMS retards individual cyclinders basted on knock? Can anybody confirm this?
Old Aug 20, 2002 | 11:32 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
The EMS retards timing based on knock and boost. You have to program the amount of retard and record a knock count that you know to be safe as a baseline. That's it. If you want to do it based off of each cylinder, you need to instal extra knock sensors, but yes it'll do it.
The AEM EMS will do anything that you program it to. All you have to do is install the sensor, configure the ECU (what pin it's on, what voltage you expect and what you want it to adjust based off of that voltage). It's totally user defineable and it's capabilities are pretty much only limited to how many unused pins are available and how creative you want to get. I don't think there's anything that anyone would want to do that the system can't handle. Want to convert a Honda to MAF? No problem. Want an EGT on every cylender and have fuel trims adjusted accordingly? No problem. Want a wideband in the car? Cool.
I own one and have it in the car now. I'll be dynoing it in a month or two, but right now it's drivable with no knock. I was intending to do it sooner but my wife had our baby a month early so spending money on car stuff will have to wait a little bit.
oneforce
Jun 18, 2014 12:49 PM
ludeking1007
Engine Management and Tuning
10
Aug 16, 2009 12:16 AM
nuro
Nov 17, 2003 09:58 PM
