Injector size GSR turbo
Old May 27, 2009 | 06:32 PM
thanh4o8's Avatar
Default Injector size GSR turbo
I have a stock gsr and i wanna run boost and hoping for mayb 250whp Daily?
Can i use 450 DSM injectors? Im also running a t3/t4 with log manifold
Old May 27, 2009 | 06:34 PM
Walterronny's Avatar
Default Re: Injector size GSR turbo
sure.
Old May 27, 2009 | 10:01 PM
dustin's Avatar
450cc DSMs will be fine. If you have aspirations for higher boost, get 550cc (saturated) or larger (if you plan on high boost some day). No reason to install a resistor box if you plan to eventually upgrade.
Stock B series injectors are 240cc and are sufficient for atmostpheric pressure (1 bar). Hence, in theory, 480cc injectors should be able to run 2bar (1 bar boost, ~14.5psi). In practice it is more complicated than that, since we use over-rich conditions to cool the intake charge and prevent detonation, atomization/intake flow characteristics, valve timing, etc. But this can be used as a rough guideline. 250whp is more than attainable with 450cc DSM injectors.
Old May 29, 2009 | 03:56 PM
thanh4o8's Avatar
Thanks for your time. I going to run mayb 7-8 lbs also how much whp can 450s handle? i dont wanna spend 300+ on just injectors .
Old May 29, 2009 | 04:12 PM
omgwtfbbq's Avatar
240cc = 180-190whp 310cc = 200-220whp 370cc = 220-280whp
440cc = 280-330whp 550cc = 330whp-380whp 660cc = 380whp-425whp
720cc = 425whp-475whp 880cc = 475whp-525whp 1000cc = 525whp-600whp
from phearable.net
AaronGeisinger
Jul 19, 2010 05:38 PM
Ek9 Kid
Jun 13, 2010 11:48 PM
boostcrazy1234
Apr 14, 2008 10:19 AM
b18c1wes
Oct 2, 2004 05:45 AM
accordselux
Jul 6, 2004 11:21 AM
