gas pedal real heavy? normal?
Old May 27, 2009 | 08:03 AM
DC5_lov3r's Avatar
Default gas pedal real heavy? normal?
the gas pedal is real heavy to push you almost have to floor it to get it going. it's 96 dx automatic, tried putting wd-40 but nothing. is this normal or is something wrong?
Old May 27, 2009 | 08:12 AM
ekb16's Avatar
Default Re: gas pedal real heavy? normal?
try some TB cleaner..could be carbon buildup on ur throttle plate
Old May 27, 2009 | 08:13 AM
TheCivicMafia's Avatar
You may have to adjust the cable or replace it, my 97 throttle cable frayed apart and eventually broke
Old May 27, 2009 | 08:19 AM
BADFISH707's Avatar
I had that problem once i took the TB off and clean the poop out of it and sprayed a little tiny bit of silicone lube spray into the actual cable. It worked perfect and also ran a little smoother.
honda00b16
Oct 27, 2010 12:20 PM
VietCloud7
May 6, 2008 04:46 PM
Yeung
Jun 3, 2004 09:12 PM
B2FiNiTY
11
Dec 2, 2003 01:37 PM
Cat
Sep 30, 2002 06:48 AM
