Vtec will not work HELP
I have had my integra for awhile now and ever since I bought it, vtec has not worked. I have tried switching out the oil pressure switch and the vtec solenoid and I know that my oil is fine.
Last fall I swapped out my vtec solenoid with one of my friends and vtec engaged with my friends solenoid. After I gave this solenoid back to him, i went through 3 different, working solenoids and all 3 of them did not seem to work. I took my friends solenoid back off his car and put it back onto mine (The first solenoid that I tried and it worked) and it did not engage. I know this solenoid works and it has worked on my car before.
With all that being said, I have NO IDEA with what is wrong with my VTEC. I am confused at why my vtec would engage with the solenoid I have on now last fall and now when I put it back on, it wont work.
I was to the point where I didnt even care anymore, but I figure I should get this working. HELP ME
I have my stock ecu. The thing that throws me off is that when I first swapped my buddies solenoid on it worked, and now I have his same solenoid on and it will not engage.
Today I just switched out the whole vtec housing along with a different solenoid and it still will not engage. I forgot to mention that my car threw codes p1259 which i know is vtec malfunction. Would that code be associated with the ecu or be thrown because of a loose connection somewhere with wiring?
i have not reset the ecu yet, just tried one of my friends ecu's out and my car wouldnt even start. any of the times i swapped solenoids my car was not shooting codes.
You can tell if vtec engages. Like I stated ABOVE, I first swapped a solenoid and I could HEAR vtec.
ANyone else have any suggestions of what it could be?!?!
And I just found out something about the ecu throwing vtec into a safe mode or something of the sort? Im trying to research it but I cannot find anything useful. Someone help me out thanks
is there oil in the motor? have you checked the wiring or ran a wire straight from the vtec solenoid to the ecu? (like you would if your car wasnt wired for vtec)
try a couple different things first then go from there
i also switched out my vtec solenoid for a friends and it worked one time wen i took it for a test run and not again after dat,
i have a factory vtec harness, i put direct power to the vtec solenoid and it clicks, i think i will try running the vtec wires
make sure you knock sensor is working and your speed sensor without that you wont get vtec run a staraight power to the soleniod if it clicks its good make sre you have a good ground
Vtec will still work when Knock is not working or plug. It's just that you ecu will go in limp mode.
