B16 Delsol wont start!!!
Old May 27, 2009 | 07:19 AM
MrMug3n's Avatar
Default B16 Delsol wont start!!!
Throwing code 15 (ignithion output signal)
i have fuel, spark, fuses are good. car starts and runs for a few seconds when i reset the computer but not long enough to move the car. usualy a wire issue.
Question is, What wires can effect the output signal. what do i need to check?
Thanks in advance.
Old May 27, 2009 | 07:23 AM
EG6Boy702's Avatar
Default Re: B16 Delsol wont start!!!
Does it run smoothly while it does run? or is it ruff
Old May 27, 2009 | 08:57 AM
Former User's Avatar
What year?
How did you check for spark?
Typically:
code 15 + no start = no spark
If you actually don't have spark, then check the igniter unit in the distributor.
Old May 27, 2009 | 11:27 AM
MrMug3n's Avatar
car runs like normal when it does run for the few sec.
93 delsol si w/ 95 JDM b16a
I pulled spark plug wires from dizzy a quarter inch to check for spark
Old May 27, 2009 | 11:28 AM
MrMug3n's Avatar
and to add to the problem its been raining all day for the past week
Old May 27, 2009 | 11:40 AM
You risk blowing your coil by checking for spark this way. Here is a safer method.
Given that the engine runs for a few seconds, do you eventually lose spark if you continue to crank the engine for 15-20 seconds?
I think you should take the igniter unit out and have it tested at an auto parts store.
Old May 28, 2009 | 08:49 AM
MrMug3n's Avatar
will do. thanks
Old May 30, 2009 | 07:05 AM
MrMug3n's Avatar
still no luck, i have spark and fuel at all times and the car will not start/stay running. timming should be fine cause when the car randomly runs for a few sec. it runs smoothly with no sputtering. any suggestions? anyone?
Old May 30, 2009 | 07:14 AM
I assume that, if you reset the ECU and crank the engine for a minute, the CEL does not remain ON and code 15 is no longer recovered from the ECU, right?
The engine running briefly does not rule out a problem with the mechanical timing. Check whether the timing belt skipped a tooth.
You also might want to measure the fuel pressure.
Old May 30, 2009 | 07:38 AM
MrMug3n's Avatar
CEL-Correct no code 15 for a few sec. after resetting the ecu
Would timing or fuel pressure lead to ignition out put signal?
Old May 30, 2009 | 09:02 AM
Has code 15 resurfaced after the ECU reset?
Old May 30, 2009 | 09:37 AM
MrMug3n's Avatar
code 15 then i reset the comp. no code 15 untill i crank the engine and car dies again revealing code 15 again
Old May 31, 2009 | 03:45 PM
MrMug3n's Avatar
Changed the ICM (ignitor in the distributor). So far the car is running ok but I will post if I find out otherwise.
Old May 31, 2009 | 03:55 PM
civic_driver's Avatar
Ron, you might want to add to your spark test tutorial that it's a good idea to remove the fuel pump fuse while checking for spark because the engine might be flooded if they crank long enough. Or I've also heard that if you put the gas pedal at WOT then the fuel injectors turn off and the car won't be flooded. Don't know if that's true or not for Hondas.
Old May 31, 2009 | 03:56 PM
heritage36's Avatar
Dang, you have owned 4 del sols? NICE!!!
Old May 31, 2009 | 05:10 PM
Will do. Thanks for the input.
Old May 31, 2009 | 06:02 PM
MrMug3n's Avatar
well now its been five sols if you count the newset blue one i bought to rebuild my 4th one lol ill say 4.5
F***'n theives
Old Jun 3, 2009 | 04:18 AM
MrMug3n's Avatar
Well after a full day of driving the car and thinking everything is fixed from changing out the ICM...i was wrong and last night the car wouldnt start again. This time im getting no CEL? still have spark and fuel as well
im wondering if using an LS ignitor plays a part? the car was bogging bad on acceleration around 3k-4.5k rpms
Old Jun 3, 2009 | 04:30 AM
b16_sol_707's Avatar
I'm using an ls igniter in my sol currently, and have been for about 3 months with no issues. check your timing? bad ecu? this is an odd problem. I'll take a look at my fsm to see what it says for troubleshooting.
Old Jun 3, 2009 | 05:08 AM
Yes, definitely check the mechanical timing if you have both spark and fuel.
Old Jun 3, 2009 | 05:54 AM
Also, when the ICM fails, the coil usually will do the same soon thereafter. Is your spark a weak orange rather than a bright white bluish color?
Old Jun 4, 2009 | 04:41 AM
MrMug3n's Avatar
fuel is ok spark is blue ignitor was from an ls and was working fine but i bought a new dizzy and will post the results after work
Old Jun 5, 2009 | 04:25 PM
MrMug3n's Avatar
New dizzy and new ecu and still no start!!! Also, when I turn the key to on, the CEL turns off indicating the ecu is throwing a code. But when I jump the ecu to check for codes there are none? And the CEL just stays on...
Old Jun 5, 2009 | 11:05 PM
Check all of your fueses. I just helped a friend with a no start problem yesterday and it turned out to be a fuse. Check all of them, under the hood too.
Are you getting fuel? does the pump prime when you turn the key?
Old Jun 6, 2009 | 07:21 AM
MrMug3n's Avatar
I will check the fuses again but they were all ok and my pump is priming. I'm thinking timing or that the cylinders might be flooded so I'll pull the spark plugs too
