driver side vibration....
Old May 27, 2009 | 05:45 AM
hard_boiled_EG's Avatar
Default driver side vibration....
i took a fishing trip to clear lake, california. on the way there i notice alittle vibration coming from the driver side, didn't think much of it until i came down alittle turn on a hill then the little vibration turned to a big vibration, i looked to see if i can tell where it's coming from but couldn't, and i was far from home so i just forced the car to the lake cause i was only a few miles from it...long story short after i forced the car home later that night, i decied to replace the driver axel in the morning, come to find out it was the axel, i guess one of the bearings inside the joint was messed up, but i still have that small vibration coming from the driver side...can it be a bad halfshaft? i checked my wheel hub and it has no play in it, has anybody had this happed before?
Old May 27, 2009 | 06:25 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: driver side vibration....
vibration can be ball joints or tie rods. check those before you drive into a lake. i have this problem now. i replace the steering rack and wheel bearing and etc. still crap.
Old May 27, 2009 | 07:33 AM
only when i accerlate though..
Old May 27, 2009 | 11:24 AM
I'm not Rick!
this is what im in the process of. checked everything and everything is fine. but still the problem is there. sucky part. start replacing parts
Old May 27, 2009 | 11:30 AM
Former User's Avatar
Check all the motor mounts:
Dragon219
May 31, 2013 08:35 PM
SpeedoKing
12
Feb 24, 2009 08:06 PM
ls eg
Jan 27, 2008 12:19 PM
Dwight Schrute
12
Aug 26, 2006 12:04 PM
90civic_tio
Feb 9, 2004 06:39 PM
