cluster issue - RPM's and MPH or temp is not working
Old May 26, 2009 | 06:31 PM
jeremyrocksursox's Avatar
Default cluster issue - RPM's and MPH or temp is not working
anyone know what could be the problem? is there a fuse that i might have to look at? i didnt see a fuse for it under the hood or under the driver side dash
the car is a 93 honda civic ex
Old May 26, 2009 | 06:54 PM
92eg_h22's Avatar
Default Re: cluster issue - RPM's and MPH or temp is not working
check voltage to cluster and get back to us! We will go from there
Old May 26, 2009 | 06:57 PM
Former User's Avatar
Check whether fuse 15 under the dash is blown.
Old May 26, 2009 | 07:04 PM
Murk 'EM's Avatar
yes as 92eg h22 said check the voltage at the plugs behind the cluster and that will tell you weather your cluster is bad or your fuse is blown
Old May 26, 2009 | 08:02 PM
how do i check the voltage? take out cluster and?
Old May 26, 2009 | 08:09 PM
Murk 'EM's Avatar
get a wiring diagram.. find out wich wires are wich and see if your getting power to ware it needs to go
Old May 26, 2009 | 08:10 PM
and if im not getting power, im guessin ill need a new cluster
cause it was working all day today, and then all of a sudden i turn my car off, and then back on 10 min later and its not working.... i really hope its just the fuse....
Old May 26, 2009 | 08:13 PM
Murk 'EM's Avatar
if your not getting power its mostlikly a fuse could be a ground to but if your getting power at the plug.. then your gonna need a new cluster
Murk 'EM's Avatar
or if you wanna save money find out wich termanils are bad and just solder a jumper wire to the ones that are bad..
however it dose sound like a fuse
Old May 26, 2009 | 08:15 PM
i would do that, but im going to be selling the car soon, so i wanna make sure its right
Old May 26, 2009 | 08:16 PM
Murk 'EM's Avatar
ok well then find out what the problem is exactly and go from their like i said it does just osund like a fuse
Old May 26, 2009 | 08:21 PM
i really hope to god it is, lol
Old May 26, 2009 | 08:26 PM
Murk 'EM's Avatar
just use a DMM (digital multi meter) and test the fuse for resistance.. MAKE SURE THE POWER IS OFF if your getting resistance then then fuse is good if it just reads O.L. or soemthing along those lines (reading no number or 0) then the fuse is bad and replace it..
Old May 26, 2009 | 08:27 PM
Murk 'EM's Avatar
or you can use a voltmeter with the power on and check for voltage but i like useing resistance for fuses cause then you dont gotta wounder if its reading right or not
Old May 27, 2009 | 10:05 AM
all its good, it was just a fuse, simple fix, thanks alot Murk 'EM for the help
honda_conversion
Jun 22, 2007 11:31 PM
superjake
Dec 23, 2005 02:08 PM
SYTFU Tommy.
Oct 30, 2005 05:40 AM
SiR HatchAlot
Mar 28, 2004 09:31 AM
Endless
Nov 17, 2002 09:44 PM
